Thanks, because I need it with this thing. I'll add another page or two to my website in the next day or two, but other things that I've run across over the last week or two....Rodney wrote:...good luck with the project.
1) Dellortos missing 3 of the 4 cable adjuster lock nuts
2) Gas tank previously sealed improperly, so it is peeling
3) Choke control mounted upside down, missing both mounting screws, one screw broken and a hole drilled next to it for a pin, and an old wheel seal used as a spacer on the handle bar for some unknown reason
4) Rear wheel bearings are bad
5) Angle of one throttle cable too severe, so I had to order an angled fitting
6) More research makes me feel that the 125 main jets will be far too small
I'm amazed at the stuff I have to repair that actually isn't costing me any money.....just time in labor.
