speedo drive
speedo drive
According to my dealer this is probably one of the next parts that will become rare.
Putting the front end back together again today I noticed the first time that the speedo drive has a grease nipple. So every couple of years one should give it some grease if it doesn`t turn freely like mine did.
The internal parts are probably plastic so it`s better not to use oil. (just a guess, could be brass or some other material also)
ducapaso
Re: speedo drive
Post by ducapaso »
Mine has gone some time ago (the brass nipple separed from the alu body and the inner gear lost :( :( :(
Still unable to replace it.
You must look at the ratio punched in the body to be sure you found an oem part: furthermore you can meet an counterclockwise gear and you might see the speedo hand go under zero level!!! :banghead: :banghead: :banghead:
Test it moving the wheel with your hand before riding it!
Re: speedo drive
ratio is 21/12
Why are you unable to replace it ? Ducati still has it and Stein-Dinse is selling it for around €40,-.
This one looks like it but it doesn`t mention axle diameter, width or ratio:
http://cgi.ebay.de/aprilia-rs-tachoantr ... dZViewItem
Finnpaso
year: 0
Re: speedo drive
Post by Finnpaso »
Can that part find from Aprilia (125cc) spare part catalogues? Just quessing now....... :smoke:
907IE -91 red/metal grey
907IE -91 red
Re: speedo drive
according to the auction:
aprilia
RS 125 1996-2005
RS 250 1995-1997
Finnpaso
year: 0
Re: speedo drive
Post by Finnpaso »
Ok, thanks! :thumbup:
907IE -91 red
Re: speedo drive
a seller on ebay told me width is 15mm, ratio is not mentined on the part and axle diameter is 20mm.
The Paso axle is 17mm. :cry:
Finnpaso
year: 0
Re: speedo drive
Post by Finnpaso »
:,( then have to make spacer to fit it to Paso.... What is wheel size in Aprilia? That can lead to ratio, but i think, its NOT 16", as in Paso
907IE -91 red
Re: speedo drive
yes, 17"
Finnpaso
year: 0
Re: speedo drive
Post by Finnpaso »
So right ratio for 907IE...... But propably again problems with axle diameter... Anyway, spacer is not so difficult to do with lathe.
907IE -91 red
ducapaso
Re: speedo drive
Post by ducapaso »
paso750 wrote:a seller on ebay told me width is 15mm, ratio is not mentined on the part and axle diameter is 20mm.
No matter! the inner spacer inside the speedo can be disassembled and switched to the other! All the speedos of this kind suppurt such job! :thumbup:
Re: speedo drive
have you done it before ? However, that only makes sense if your original housing is broken, not if something inside is defect.
I was discussing with Antti before, what washers/spacers are on the left and right side of the front wheel ? I found only one. According to the parts catalogue there`s one that comes with the speedometer drive. How does that one look like? Anyone have pictures, what are the measurements ?
ducapaso
Re: speedo drive
Post by ducapaso »
paso750 wrote:have you done it before ? However, that only makes sense if your original housing is broken, not if something inside is defect.
When I disaswsembled mine, I tried to install another one, with different inner diameter, but it was an unclocwise spinning! :(
Desmo_Demon
Re: speedo drive
Post by Desmo_Demon »
Lat week, I just had the tab that fits into the front wheel break on my Paso. I had a spare speedometer drive unit, so I installed that one. Does anyone know if I can buy just the back plate with that tab? That piece is easily removable with a simple retaining ring that you can pull out of the unit with your fingers.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
cagiva905
year: 0
Re: speedo drive
Post by cagiva905 »
I had a similar problem on the speedo drive of my 350 Elefant a few years back (similar drive). I was able to weld the notch back on the ring, and thoroughly cleaned and greased the inner parts. I was not able to disassemble it completeley but the ring came off. I put everyting back together but also, to prevent twisting of the ring, I put some strips of neoprane tape on the ring that now is pushed flush with the gear by the wheel hub. No problems so far :)
Michiel
http://www.elefant.nl
http://www.endless-horizons.net
