Page 1 of 3
Oil level and sticker (again)
Posted: Mon Jun 21, 2010 8:59 pm
by micklm
Hi all,
Ok this is a stupid question and a repost of an old topic
http://forums.ducatipaso.org/viewtopic. ... +max#p2992 BUT I've looked in the owners manual, searched and read the topic above and still ain't sure.
Every other Duc I've had has two lines next to the sight glass for the min and max oil level. Like PHOTO 1. But my 906 Paso (and others apparently) has a little sticker that fits perfectly between these two lines that shows the max level as at the lower of the two lines cast on the side case. Like PHOTO 2.
PHOTO 1
Probably like everyone else with a 906, I keep the level between the two lines cast on the side case and ignore the sticker.
But it's bugging me....probably cause my front cylinder has a persistant oil leak that a strip down and oring replacement has failed to fix. Hmmmmm...
And yes I know the level is a little low - is down for maintenance
Anyone? Thoughts?
Mick
Re: Oil level and sticker (again)
Posted: Mon Jun 21, 2010 11:49 pm
by Tamburinifan
Same problemo here,
and my cover looks like your photo 2.
I`m also
Posted: Tue Jun 22, 2010 12:29 am
by higgy
Don't have the documentation to prove it but my guess would be they are both max levels. One cold and one hot.
Posted: Tue Jun 22, 2010 8:10 am
by micklm
Higgy,
That makes sense I think - although I still wonder why they went to the trouble of making a new sticker for that. First water cooled model I suppose.
It's a bit redundant having a max hot level though isn't it ? what do you do if when you fire it up the hot level is above the sticker line
I wonder if these stickers/decals are on the 907's as well?
I suppose I'll continue filling to the mid way between the cast lines on the side case and ignoring the sticker as always - anyone else do different?
Mick
Posted: Tue Jun 22, 2010 9:28 am
by paso750
If you fill it up to the top mark and put the bike on the side stand it will probably be at the lower
just kidding
Posted: Tue Jun 22, 2010 10:14 am
by higgy
just kidding
I like that one G, but I think you will find when you fill it to the upper level on the center stand and then put it on the side stand the oil will be below the window completely. Wanna know how I know that ?
by the way,oil level should not be checked when the bike is on either stand
This is a fairly common practice industry wide
I'll take a look
Posted: Tue Jun 22, 2010 12:29 pm
by Tamburinifan
Yup (see my reply....).
Posted: Tue Jun 22, 2010 12:55 pm
by higgy
I assume your 907 to be a Euro model?
Posted: Tue Jun 22, 2010 4:17 pm
by Tamburinifan
Yes.
Posted: Tue Jun 22, 2010 5:22 pm
by higgy
Posted: Tue Jun 22, 2010 5:45 pm
by micklm
Higgy - I wasn't aware of this hot/cold thing (being a young-un). Thanks! I like the three line, no sticker twist......
Tamburinifan - sorry mate, I hadn't noticed you had a 907!
G - is that with 16inch wheels and a 906 stand, 17inch wheels and 906 stand or 17 inch wheels and a 907 stand
Mick
Posted: Tue Jun 22, 2010 6:20 pm
by persempre907
On my 907s there's the same sticker with the lower oil level.
Could an extra oil filling break something so that there's an oil leak????
Posted: Tue Jun 22, 2010 7:32 pm
by higgy
Too much oil can blow crank seals,cause hard shifting and in extreme cases break a piston. If I had an issue with repeated oil leaks between cylinder and head mating surfaces and can't find any other source or reason, I would have to suspect an oil pump issue as in a faulty bypass spring or some sort of odd restriction in an oil passage.
Posted: Tue Jun 22, 2010 9:06 pm
by JWilliam
If the Oil is filled over the top line then Oil can leak out of the filler cap making it look like the oil window is weeping. Anyway, try 3 litres of Oil not 3.5 litres if you think there is too much.
P.S. if there is a persistant leak after rebuilding the engine then you should use Tri-Bond between gaskets, available from Ducati.
Posted: Tue Jun 22, 2010 11:58 pm
by Tamburinifan
Please develop above statements, higgy,
what spring could be faulty f e?
Strangest thing f me is,
it is the same cases on all 90`s engines,
how/why did this odd marking occur in the first place?
