Swingarm Swap
- BikerBard
Swingarm Swap
I'm in the middle of the swingarm swap and I'm cussing the #*$%^&!!! designer of this bike! The service manual says to simply remove the bolt at the bottom of the shock...the bolt holding the connecting rods on the swingarm....and it should simply fall out. HA! they fail to mention that the freaking exhaust pipe runs thru the middle of the thing! I'm giving up for tonight and will finish sometime tomorrow (I hope). Here's hoping none of y'all have to do this anytime soon :thumbdown:
DG
DG
Donna G
'12 Moto Guzzi V7Racer
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
- Desmo_Demon
Ooohhh...great!
Just another thing for me to look forward to with my Paso project, as I am thinking of taking the swingarm off to inspect the bearings, seals, pivot points, and torques....I just don't trust what the previous owner did to the bike. :ugh:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Finnpaso
- year: 0
I would also go that way... Simple job to take all exhausts pipes away!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Skins
I've had the swingarm spindle out when I've removed the engine, but I've never taken the swingarm off. However, the manual says (under Removal and Overhaul of Swingarm) to put a hydraulic hoist under the engine (I had ropes from a beam coming down to take the weight of the engine), then remove the spindle, then (quote) 'extract complete swing arm with bushings and spacers'.
So, it would seem that with the weight of the engine supported, there should be nothing to stop you pulling off the swing arm once the strap, shock, and spindle have been removed.
- BikerBard
hehehe, it finally came out. Just needed to be man-handled. (or should I say...girl handledjcslocum wrote:Might need some persuading with the mechanics best friend, the 5 lb. hammer?
The new one is in and I'm fixing to tighten everything back up and get the wheel on. I'll post some pics of the damage when I get a chance.
Thanks to y'all for the advice
DG
Donna G
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
'04 Vstar 1100
'88 Paso 750 (blue)
'74 BWW R90/6
'71 BSA
'62 Triumph T100C
- Skins
I reckon that's a bit tight, Nicola. I prefer almost 1 inch slack with the suspension half compressed. You need a good bit of slack to absorb engine and transmission vibrations, if you want a really smooth ride.
A good way to compress the suspension is with a loop of heavy rope over the seat and through the wheel, with a towel for padding. I use the rope that controls the main sail on my sail boat, but lots of turns of a lighter rope would do also.
- Skins
Good on ya, Nicola! I reckon you can feel the difference in vibration of different tensions when you ride. At low speeds, up to 75 km/h (45 mph) a slacker chain (up to 30mm/ 1.25in) can give you a really smooth ride, but at higher speeds it needs to be tighter, no more than 25mm/1in.
I reckon the chain is the soul of the machine.
