I noticed that the clutch lever was not feeling quite the same so I figure about time to check the fluid and it appeared down a bit so I topped it up and followed the procedure for bleeding. Got out the old fluid while adding more. Now no clutch at all. I figure the prob could be at the master cylinder as there is no pressure. Perhaps it sucked some crud in. You can leave the cap off and the stuff should fly out like it did when I did this by accident.
