Speedometer
Speedometer
Hello Pasofriends. Recently my Paso has broken the speedo part situated in the front wheel (I don't know the correct name in english). I have read that this part is like one fitted in a Aprilia bike, but I can't remeber wich model, and where I have read it. Can you help me?
70 hp. can change the world
I would contact some race shops, most racers take the speedo drive off and substitute an aluminum spacer, somebody must have a stack of them somewhere!
- ducapaso
You mean this?
http://it.msnusers.com/pasochisti/shoeb ... &PhotoID=9
There's a ratio number punched in the body, mine is 21/12 and refers to the gear inside it.
I happened the same thing and I went searching to an "used spare parts fair" (is there a sigle word for this?)
You must take care not to find a left spinning speedo, even if a similar ratio (such as 19/11) will do
ex...Red "smooth" 753349
