Hi everybody,
I have bought on eBay from a canadian seller a couple of stock mufflers.
The seller has shipped to me also a chip (n. 91270201A) that increases the performances of 907 ie USA.
On the attached paper I can read that: "With these modifications you'll change the data submitted for the motorcycle type approval; therefore use the modified motorcycle only within closed tracks".
On the chip it's a label: "DUCATI 907ie -023U-".
Could I use it on my european 907? How does much would be the performances increase?
Ciao.
Racing chip?
- persempre907
Racing chip?
- Finnpaso
- year: 0
That is NORMAL USA chip for 907IE, and that chip is designed to tune engine MORE LEAN, than normal 907 Chip, what is marked -023- That "U" means, that its USA chip. Its safe to use that with EURO bike and with normal mufflers, but it is NOT so good, as EURO chip)-023- ; what is more rich mapped. Dont use ever that USA chip with open muflers, or then You have maybe big problems with burned exhaust valves! You are warned now!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
- Finnpaso
- year: 0
Yes, not anymore horsepower, cause more lean fuel ratio, than in normal EURO chip -023-. Near allways USA Ducatis have been fitted with leaner chips, cause there are tighter emission rules = leaner fuel ratio. So, NO "RACING chip", i am sorry, Francesco!
907IE -91 red
907IE -91 red
1564
- persempre907
