Fan thermo sensor/switch
Bzapcat
Post by Bzapcat »
Apparently my fan thermo switch is bad. Does anyone know of a replacement for the sensor/switch ? I've read that it's a common sensor/switch. But I am having a hard time finding one that is a correct fit. Of course I can always run a bypass switch but I'd rather use a workable thermo switch. Thank you!
Derek
Re: Fan thermo sensor/switch
Post by Derek »
That thermo switch was used on the 906, 907ie, 851, 888 and 9176 and early 748 but is no longer available.
https://www.stein-dinse.biz/product_inf ... _id=114492
However the switch for the later 748 and the 996 is available. It is essentially the same switch but with a different connector. It would need the connector of the 907 loom changed to fit.
https://www.stein-dinse.biz/advanced_se ... gories_id=
du907
Post by du907 »
A lot of this type of part was also common on cars. Isn't there a site or posting of common parts that where also used on cars at the time? Maybe it's on that list.
Bzapcat
Post by Bzapcat »
Thank you Derek! I did a search for the 916 temp switch and found an aftermarket switch a lot cheaper. I also picked up a "lower" temp switch and installed that one first. It has the same electrical terminals as the 907. Thought I'd give that a try first before cutting and splicing a electrical plug for the newer style.
Finnpaso
year: 0
Post by Finnpaso »
Can You put some link here about that 916 switch. I mean, that where You bought it and what was price?
907IE -91 red/metal grey
907IE -91 red
Witzie
Post by Witzie »
for my 906 I ordered a Febi Bilstein 06031 fan switch which looks exactly the same. 22 x 1.5 mm thread , 92 and 87 C switch temps. I have yet to find out if it fits but it most probably will
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994,
Kawasaki ZZR1100 1993, Ducati Paso 906 1989
