Clutch master cylinder
ducatipete
Need to over haul my master cylinder, assume its a Brembo, what diameter is the bore/any part numbers? many thanks Pete
- Derek
- year: 1994
Re: Clutch master cylinder
I'm pretty sure you need a PS13 seal kit but it may be a PS12. Both are available from Gutsibits
http://www.gutsibits.co.uk/pr/TheShop/i ... r=+FILTER+
have a look at the bottom side of the pump. There should be a number stamped on the housing.
ducatipete
thanks, will have a look weekend...
