Rough Running 907ie
Coffee_Kid
Rough Running 907ie
Post by Coffee_Kid »
I just about finished eveything on my 907, but haven't riden much in a while getting it done. I have all the standard upgrades, K&N, Conti Slipons, proper sprocket, etc., but have noticed a vibration from the motor pulling at around 6k rpm. I can't tell if this is normal vibration or a sign of something amiss. Any input as to what I should expect from this bike to be smooth as silk at speed would be helpful.
The tech who tested the bike after a tire instal mentioned he thought the bike ran a little rough, but since it hasn't done 150 miles in the last two years, I don't know whether to chalk it up to being taken off bed rest.
I have just shy of 12k miles and the bike is mechanically sound. Running the stock chip (the Ultimap chip I tried today was, I believe, defective)
No knocks, no ping, everything seems fine otherwise except for the leaing out at speed with the factory chip.
Thanks,
Michael
Glendale, CA
pencilbeam
Post by pencilbeam »
My 907 comes alive at about 6,000 with no vibration. No idea if its a chip problem, but check your motor mounts to make sure they're not loose and take a look at the spark plugs. that will tell you alot about how the motors running. All the basic stuff, like your battery charge fuel filter, old gas in the tank makes all the difference at running speed.
Coffee_Kid
Thanks, back to the drawing board.
I had sipped and coated the inside of the tank before repainting it,though I don't seem to have a loss of power issue. I am due for belts and a valve adjust and will check the mounts at the same time.
Feels like I'm sitting on a Harley or something. The new Conti's are pretty loud, and I wonder if that could be affecting the feel of the bike with the stock chip.
Thanks again,
Michael
Rlbol
year: 0
Post by Rlbol »
coffee how are the contis? any pictures?
Finnpaso
year: 0
Post by Finnpaso »
Contis are BEST EVER made mufflers to Paso !!!!! :thumbup: :thumbup: :thumbup:
907IE -91 red/metal grey
907IE -91 red
Rlbol
year: 0
Post by Rlbol »
do you know of any where to find some pictures of them??
Finnpaso
year: 0
Post by Finnpaso »
Try search by Google! :D Btw, Conti have made at least 2 different style pipes: Those early "trumpet style"(what are best ones) and later 2 to 1 alumium sets. You can see those trumpet style Contis also in many MHR bikes. :thumbup:
907IE -91 red
Coffee_Kid
I've been trying to get them posted here (pictures), but admin is a little behind.
I am a little biased, but I think they look pretty sweet. THey are certainly loud--set off a few alarms already. Fresh black paint with too much clear coat, black reflective decals that glow in direct headlights, Corbin, Contis, Euro tail light, K&N and a new Ultimat chip that could use a bit of tuning I think.
It's taken a long time to get it together, but with only 11k miles, it should serve for a while.
I also rigged the front (next the rear) marker lights to stay on while running yet flash when in use. A black bike could use a little help, I think.
The decals are black during the day.
Here's a picture:
Image (alt+p)
[/img]
Finnpaso
year: 0
Post by Finnpaso »
Those are those "newer style" Contis. But must ask, are those 2 to 1 System, or 2 to 2 ??? :confused: Btw, Contis are ALLWAYS loud, so they are "REAL" mufflers to Ducati. Ducati must be loud !!! :D :D :D
Want to ask, is that black part of pipes repainted/recoated??? :confused:
907IE -91 red
Rogero
Post by Rogero »
Looks good, proves you can change perfection :thumbup:
Interested in the decals, black by day and white by night / light..
Rogero
1992 "Red" 907 I.E.
Rogero
Post by Rogero »
Rogero
1992 "Red" 907 I.E.
persempre907
Post by persempre907 »
Very nice, good work :thumbup: !!
Coffee_Kid
They ae 2 & 2, slipons of a sort.
The decal material is available at most vinyl shops and in a number od colors. I seriously considered stock, but was leaning more towards the stealth idea. If they have to ask what kind of bike it is . . . .
Thanks for the comments, I am going to install new Denso plugs today to see what they will do. Having just put the thing together, I am not looking forward to a valve adjust and belts; but I'm due.
If you google reflective vinyl, a lot of shops will come up. If someone wants the artwork, I can email it to anyone interested.
Finnpaso
year: 0
Post by Finnpaso »
If so, those Your 2 to 2 system are much better, than 2 to 1. There have been many problems wit 2 to 1 systems.... :thumbup:
907IE -91 red
Rlbol
year: 0
Post by Rlbol »
Nice looking bike Coffee!
I have tried searching the exhuast and found nothing. If any one has some pictures for the older style could they post them up, thanks
