While I was painting the ST2 heads with VHT satin black I took the opportunity to remove and repaint the engine covers at the same time so it's all looking good now.
I just need to fit the bodywork panels back on and wait for the snow to clear
Tamburinifan wrote:Any mapping done, Derek?
It's something I should give some consideration to although I'm not sure how to go about it. A Power Commander and a dyno run would be the easiest way but not cheap, but this bike isn't going to be getting thrashed and I doubt if a 40cc increase in capacity will make a lot of difference to the fueling requirements.ducbertus wrote:Good question, Gert!
Derek, with these changes in the mechanical parts of the engine a remapping can be fruitfull.
running lean in some area's of the powercurve can damage the engine in long terms.
Bertus
Three valve covers were in good condition and didn't need painting. As you would expect the horizontal exhaust cover was fairly sandblasted and needed a re-paint. The "gold" finish is actually a mustard yellow colour. The nearest I could achieve was to paint the cover with yellow Hammerite smooth then give it a light overcoat of gold.du907 wrote:Did you paint the valve covers the gold color? If so, what color of paint did you use?
Anyone have a suggestion on the goldish color of the valve covers? I have heard a Honda color is close.
du907
