i just soldered some copper capillary tube to a small refrigerant strainer and connected two small 3/16 copper ends to the capillary which is the same size as the pressure sensor tube connectors and reconnected this gadget with the rubber tube and small cable ties, the top capillary tube is 1.2mm and the bottom 1mm in dia. see pic
this gadget acts as a muffler and should smoothen things out from any fluctuation, but still giving the correct absolute atmospheric air pressure from inside the air box...i didnt try it out as yet
