Mains - 145
Air Corrector - 170
Idling Jet - 55
Pump Jet - 40EW
Starting Jet F7/110
When the fuel pump is running I've pulled the Main Jets and the fuel is at the bottom edge of the emulsion tube. When cold it starts with the choke but runs rough then dies. Here's a couple of questions I have;
1) With the pump running but the engine isn't and I crack open the throttle I don't see any fuel squirting into the barrells. Should I?
2) When the engine is turning over and the throttle is wide open I see a little weak "spray" activity from the one barrell but not the other. Checked the fuel level in both tubes and it's right below the emulsion tube.
Any ideas?
Update - I've confirmed I have fuel flow through my venturi's. On the bench, I can spray carb cleaner through them and I have cleaned them out. But there is this small passage (A) in the accel pump that leads to the pump jet. In the bowl of the carb is another small hole (?) that doesn't go anywhere. Should it be feeding the backside of the accel pump?
