Got Oil?
Re: Got Oil?
what are the best oils for use in our bikes?
nnnnnnorman,any oil with a minimum rating meeting the manufacturers requirements will do the job. The important factor to consider is your normal range of operating temperature. Synthetic oils generally have a wider range of temperatures they can handle than non synthetic oils
nnnnnnorman
Re: Got Oil?
Post by nnnnnnorman »
thanks higgy. :cool: :) :thumbup:
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Re: Got Oil?
One more additional thing in passing
Big diesle engines these days use what is called a bypass filter. There are engines in use with a million miles of heavy duty service and have never had their oil changed. They are now using them on motorcycles as well
http://www.amsoil.com/bypassfilters/vansise/index.aspx
http://www.blackstone-labs.com/by-pass- ... ration.php
http://www.gulfcoastfilters.com/
Almost any heavy equipment service center can do the required testing to extend the time between oil changes for under 20 bucks USD
streetsurfer
Re: Got Oil?
Post by streetsurfer »
Amsoil 20W-50 in Paso and LC4.
I've used Amsoil almost exclusively in everything mechanical since around 1976 when introduced to it (the days it came in metal cans). Being minutes from a regional warehouse helps.
