Play on rearwheel
hvv
Play on rearwheel
Post by hvv »
I have deteced some "play" (is this good English?) on my rearwheel. When I put the bike on the centerstand I can move (Wiggle) the rearwheel. It is not much but I suspect this indicates that the bearing are worn.
Does anyone know howmuch "play" is allowed and should I replace it rightaway? My fear is that the rearwheel could jam while I am having a go!
I also noticed that the rear break can move a but forward and backward (in the direction of rotation). Is this normal?
Would be great to have some comments!
regards,
Hans
Skins
Post by Skins »
:cool:
Yes, 'play' is the correct word, hvv.
The workshop manual doesn't specify any allowable play, but just says the bearings should be replaced if there is 'excessive' play. On my bike I could not detect any play in either the wheel bearings or the brake assembly. I think you should take it all apart and have a closer look.
hvv
Post by hvv »
Thanks Skins
I thought so too but thanks for the confirmation.
Hans
Paul
Post by Paul »
hvv,
I don't think that you should be able to detect any play at all. If there is play something is wrong. I also think you are right to strip it and have a look.
Paul
hvv
Post by hvv »
Paul and Skins thank you for your reply's. I feel kind of stupid but I found the cause. It was something that should have been checked first: the rear wheelnut was not tightend properly. I fastened it and the play was gone.
Hans
Skins
Post by Skins »
:thumbup:
Good stuff, hvv. Do you think your chain tension is OK now? It's very important to get that right.
hvv
Post by hvv »
Skins,
You are like a father always looking out for us!
I will check it
Paul
Post by Paul »
And sometimes he is like a wife... :roll:
Paul
ducster
Bearing Dimensions
Post by ducster »
Hello,
even though you have fixed, please get the Rim out and check the bearings!
If you still have the 16" OSCAM Rims like 906Paso, here are the dimensions of the bearing:
Outer Diameter: 42mm
Inner Diameter: 20mm
Width: 16mm
The FAG (Bearing Manufacturer) number is: 63004.2RSR
Left and right side are equal, costs are (Germany) about 17,- Euro each.
There are two more bearings placed in the chainwheel adaptor. Can't tell you more about this ones... :oops:
But check them too!
Had the same prob a couple of days ago, broken outer ring... :mad:
Hope it would help you.
Greetz,
ducster
Paul
Post by Paul »
Great information Ducster. It is always good to have the OEM name and part number. Saves a lot of money over having to buy from the Ducati Authorised Dealer...
Paul
ducster
Post by ducster »
:thumbup: of course it does! Tried to get the bearing at the local Ducati dealer... He only had the microfiche from 907ie and would like to sell me a couple of bearings from M900-900ss??? :evil:
Instead he did not recognize that 906 had 16" rims :ugh:
Good for me that i've had the rim in car, so i could verify the item :cool:
Dealers handling of my request felt for me just like: Get this "terrible horrible old fashioned bike using customer" out of my "new fashioned fully designed ultra-elegant Yamaha-Triumph-Ducati Shop"! :screwy: :thumbdown:
btw: a local bearing manufactury, called IBC (very competend and helpful people there! :thumbup: ), could deliver every standard metric sizes only. The bearing of the OSCAM's is a low frequented model and out of normal metric range. Seems that only FAG is producing this ball bearing. Thank god there are some more bearing dealers in my nearest country, so i could get some after, :confused: i think, 3rd request.... :cool:
btw2: is my "old fashioned" shool-english just understandable? :confused:
Skins
Post by Skins »
:thumbup:
Your English is crystal-clear, Ducster! And welcome! It sounds like you're going to be a good man to have aboard. We've got quite a few now.
hvv
Post by hvv »
Great info Ducster,
Super gut, Toll, Spitze.......
Hans
KillerB
Post by KillerB »
I have a little tip about ball bearings. As you probably know, the bearing number is usually stamped on the seal, shield or sometimes the bearing itself. These numbers are an international standard. Before going to a bearing house, or heaven forbid, the dealer, check with a local electric motor repair shop. If they are anything like me, they will keep a good selection of bearings in stock at about half the price of a bearing house and much less than a dealer.
Regards, B
Martian
Post by Martian »
hvv,
If you had continued to ride, (with excessive rear wheel play), you may well have had to, (ultimately), join the 'Paso Oil Leak' group!
Glad you found the cause of the problem.
The generic bearing numbers are very, very useful - thanks ducster.
I will be having a 'away day' from the Paso, tomorrow, as I have to take my son to Heathrow airport in the morning.
Safe riding.
