Paso 750 Rear Tire solution (160/60/16)
- randtcastell
Re: Paso 750 Rear Tire solution (160/60/16)
Got it E.
I plan on riding W. Marin Jan.1. I think it will be dry that weekend.
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
- fredskidoo
Cool - do me a favor if you can remember and shoot me a reminder please -
'87 750 Paso 751412
Hi all, I have'nt posted for a while. I just had a new set of the Shinko tires mounted. The mechanic had to shave the drive side side wall as others have said. All looks good but I won't be riding for a few months as I live in the norh of the US. I'm looking forward to testing the tires out.
A pic of the shaved side on bike would be interesting.
I can't get any pictures for a while as the bike is in my van that is buried in a snow drift.
- Skins
Wow! I'm so glad I live in a temperate climate!
- 907pasonut
I went skiing in NZ during the early 90s and you had 8 metres of snow on Mt Hutt...the snow level was up to the top of lift towers...they had to dig trenches for the lifts to operateSkins wrote:
...sometimes not so temperate
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
I just read on another forum (Concours.org)that 757s have been recalled and that "757s won't be back in production...the replacement tire is a SE790 Journey"...??21783mike wrote:WTF is wrong with you guys..... Either everyone has an engineering degree and works for the govt which makes it necessary to make everything so freaking complicated to justify the wasted years of your life you spent in college to learn nothing..... or have taken so many yoga classes that you think having your head up your ass is normal.
It's this simple, put tire on rim, remount on bike (yes chain and all), wait dont take bike off of rear stand yet.... get out regular old trusty angle grinder like this one - http://www.makita.com/en-us/Modules/Too ... ?ID=316402 Have a friend ect... spin tire by hand at an even and consistent speed while you grind off enough rubber to stop the tire from contacting the chain, (yes just use the normal freaking grinding disk.... yes the flat surface of it you douchebag) then grind off a little bit more just because I said so. By the way if you and your friend are dumb enough to do this without eye protection on good, maybe you will learn that you should by losing a freaking eye.
Now take bike off stand, put on your riding gear and ride the damn thing.... no don't bother looking at the thing again and re over thinking it, just lube and adjust chain, and keep proper air pressure in the tire.... if it rubs a little so what that will keep that side of the chain clean. JUST LEAVE IT ALONE NOW UNTIL THE TIRE WEARS OUT.
So in short only these things are needed -
1. New Shinko 757 180/60-16R
2. Rear stand
3. Angle grinder with grinding wheel
4. Common Sense
I understand that some may be offended by this post, those will be the same ones who do not have #4 in the above list. My suggestion to them is to sell all motorized transport in there possession and utilize mass transit as a favor to the rest of us, and for the saftey of society in general
Supposedly, you can contact Shinko through their Facebook page.
Depends on what is...is.
- randtcastell
"WTF is wrong with you guys..... Either everyone has an engineering degree and works for the govt which makes it necessary to make everything so freaking complicated to justify the wasted years of your life you spent in college to learn nothing..... or have taken so many yoga classes that you think having your head up your ass is normal."
I suggest you grow up and learn how to express yourself as a man (if you are indeed one) or stop your attempts to communicate. You seem ridiculously overwrought or insecure. Dude, get some professional help. I hope things improve for you.
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
- fredskidoo
Back on the tire topic. Here are some pictures of the my newly mounted tires. I tried to show the clearence of the chain to the tire but it doesn't show real good. Also the front fender was raised slightly for the new front tire. There is also more lean when on the side stand due to the taller rubber as has been discused earlier. A simple alturnative for new tires.
http://public.fotki.com/loki1957/1987-ducati-paso/
- 21783mike
randtcastell wrote:"WTF is wrong with you guys..... Either everyone has an engineering degree and works for the govt which makes it necessary to make everything so freaking complicated to justify the wasted years of your life you spent in college to learn nothing..... or have taken so many yoga classes that you think having your head up your ass is normal."
It's called sarcasm JR. One day when you grow up you will be wise enough to notice sarcasm
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
- 21783mike
loki1957 wrote:Back on the tire topic. Here are some pictures of the my newly mounted tires. I tried to show the clearence of the chain to the tire but it doesn't show real good. Also the front fender was raised slightly for the new front tire. There is also more lean when on the side stand due to the taller rubber as has been discused earlier. A simple alturnative for new tires.
Beautiful, do you plan to put an extension on the foot of the stand? I haven't yet but suppose I should put that on my list of things to do this spring. Or maybe just put the center stand back on......
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
thanks loki1957 for going back to the topic of the thread and for the pics.
may you give us some additional info regarding the modification.
which tire brand? how did you solve the clearance issue between the rear tire and everything around.
thank you, hardo
thank you, hardo
Hi Hardo,
If you want you can show up ones, and I can give you details. I did the conversion one year ago on my paso 750 and it works perfect (see pics on page 4). I ones started a documentation to put it here on the webside. But had no time to finish it (to much work). Few month ago could get a cheap and nice 906. I will do the conversion on it soon. If you are one's near Bern let me know. If i don't mistake I've sent you my coordinates already.
Paso 750/ 1987
Paso 906/ 1992
Paso 906/ 1992
