Carb convert.
Re: Carb convert.
Post by Tamburinifan »
I plan to work on the mapping.
How?
Hex & burning?
Re: Carb convert.
How?
Hex & burning?
Most likely. I have about a half dozen maps to try at present so just chip swapping to start. Want to see whats been done already then go from there. I'll do the checking on the dyno with the LM-2 to save some time then do some on road verification .
I also have four exhaust systems to test for the 907,Staintune, F1, Stock and My modded stock,Oh almost forgot and the Rennsports off the 906. Oh, just so G can be happy,I might even put the Weber on it just for giggles and to prove a point. :lol: :lol: :lol: :lol: :lol: :truck: :truck:
samandkimberly
Re: Carb convert.
Post by samandkimberly »
907pasonut wrote:Didn't some ducati rider kill themselves because the cast iron rotor or rotors shattered? :huh:
You might be thinking of Jimmy Adamo here in the US - died in a crash caused by a shattered *carbon* rotor, back when the technology was rather new.
Sam
samandkimberly
Re: Carb convert.
907pasonut wrote:...and to fit carbs on a 907 its a major job, and would take ages...
It's not that hard. At it's simplest:
buy a set of 900 SS intake manifolds off of ebay
buy a Mikuni vacuum fuel pump off of ebay
buy a Keihin FCR carb kit for 900SS (includes cables, twist grip, etc.)
buy some pod air filters
Rip out everything under the tank, including the fuel pump, and put the new stuff in. Plumb the vacuum fuel pump off of one of the vacuum ports, pulling fuel from the tank and pushing via tees past the carbs and back up into the tank as in the original fuel loop. Bingo, you have more space under the tank, and a better running system for a day's work and $1,250.00 or so. sell the old parts and you're out less than ~1,000.00.
More than I want to spend, but easily doable with basic tools and skills.
Sam
907pasonut
Re: Carb convert.
Post by 907pasonut »
my motto is...if it aint broken dont fix it...I dont know much about superbikes, but didnt ducati won a few world championship titles on their 888 in the early 90s...surely they must of had a p7 or p8 FI system and not carbs! I might be wrong and if so someone correct me, but if that is the case...I rest my case :beer: :beer:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
persempre907
Re: Carb convert.
Post by persempre907 »
907pasonut wrote:my motto is...if it aint broken dont fix it...
My friend mechanic always tells me the same... when I have some fun idea...
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
samandkimberly
Re: Carb convert.
I agree. The only reason I'd change the EFI system is to learn. Other than a cold start hiccup or ten it's fine by me.
The enemy of good is better.
Sam
907pasonut
Re: Carb convert.
:thumbup: :thumbup: :thumbup: :lol: :lol:
Cheers Claude.
Re: Carb convert.
yeah, ... and after tight comes loose :)
Re: Carb convert.
The first injected racing Ducati,I believe was the 4 valve 851 in 1985
angelix
Re: Carb convert.
Post by angelix »
I it was a little later, in january 1986 Ducati started testing and the first appeareance was in Septemper 1986 at the "Bol D'or 24" with a 748cc LC 4V Fuel injected with a Marelli EFI.
907pasonut
Re: Carb convert.
paso750 wrote:yeah, ... and after tight comes loose :)
:lol: :lol:...the crankshaft oil plug... :evil: :evil:
Cheers Claude.
samandkimberly
Re: Carb convert.
Here's another relevant quotable quote:
"Make the suspension adjustable and they will adjust it wrong ......
look what they can do to a carburetor in just a few moments of stupidity with a screwdriver." -
Colin Chapman, F1 designer, and founder of Lotus, speaking of his customers
Re: Carb convert.
:lol: :lol: :thumbup:
I`m one of those idiots....
persempre907
Re: Carb convert.
That's because I haver never tried to adjust both suspensions and carburettors :mrgreen: :mrgreen:
