You can see it on the Bauke Miedema's site.
The carbon fairing is the final modification for improve the handling.
![Image](http://www.geocities.com/750paso/pictures/side.jpg)
* high compression pistonsredpaso wrote:Nice paso (not that I have ever seen a bad one).
A few interesting mods there by the looks, what has been done to it
Ciao Gherard vedo con piacere che hai continuato a modificare il tuo Paso.paso750 wrote:Ciao Stefano,
my list is meanwhile a good piece longer, only the list of engine mods is so longvery similar to yours though with Mikuni TDMR 40s, 780cc kit, DSM torque cams, Carillo rods, slightely lightened crankshaft, lightweight flywheel, programmable ignition, the biggest valves possible etc, etc.
I`m still working on the new airbox so she wasn`t on the dyno yet.
Aren`t the Marvics 5x16 or am I`m mistaking this (I have a set at home and would have to check).
What about the glassfibre tank. I remember discussing with you longer time ago that the tank wasn`t holding the fuel 100%. Was this solved ?
Do you use an airbox with the Keihins ?
saluti,
Gerhard
PS: hai dimenticato il panello instrumenti della Supersport. Dove hai trovato il disco freno posteriore, questo ancora mi manca ?
