Does anyone know if one from a 851 will fit?
Thanks in advanced.
Duncati.
Sounds more like bad starter solenoid or battery.a nasty click, click under the saddle
Don't forget a faulty spragclutch..! Mine was gone and this is noticed when the starter turns free with, in my case, a loud click at the end. The click was caused by 'grabbing on' from the sprag clutch again.Tamburinifan wrote:Sounds more like bad starter solenoid or battery.a nasty click, click under the saddle
Start motors usually only suffer from worn brushes or bad/corroded connections.
Did they mount the sprag backwards or what?i noticed when they turned the engine over that everything was turning the wrong way round
