K&N weber jets
Duncati
K&N weber jets
Post by Duncati »
Dear Gents, I have a K&N airfilter I want to fit, :huh: does anyone know what jets I have to replace? I am sure someone knows, thanks in advance, :thumbup: keep up the good work. :mrgreen:
Duncati.
A day when you have not ridden, is a day you have not lived.
nilaus
year: 0
Re: K&N weber jets
Post by nilaus »
Hi
What cans are you riding with?
I ride with open, golf ball roll thru types and K&N filter, and I can recommend the below. This is what I have fitted, and it is ok. I would like to fit a fuel regulator. This should also help. *=changed
Choke:36
Ventury: 350
*Main jet: 160 *
Air corrector jet: 170
*Ideling jet: 60 * (65 is to rich)
Air ideling jet: 130
Pump jet: 35
Starting jet: F7/110
Needle valve: 300
Kind regards Klaus
Brutus
Re: K&N weber jets
Post by Brutus »
Duncan, I've fitted a k&n and didn't changed the setting. Mine allmost runs perfect..!
Duncati
Re: K&N weber jets
Post by Duncati »
Hi Leon, kuip stuur ik zaterdag met post, I have tried the filter without rejetting but I get a lot of backfire out of the right hand exhaust :x , can not seem to get mixture right even with a vaucum gauge? :,( , runs ok without filter.
Duncan.
jcslocum
Re: K&N weber jets
Post by jcslocum »
nilaus wrote: I would like to fit a fuel regulator. This should also help. *=changed
Kind regards Klaus
Klaus,
Is this what you want?? http://www.jegs.com/p/Mr.+Gasket/747753/10002/-1
or this: http://www.jegs.com/p/Holley/745059/10002/-1
You can but it and send it to me and I can then resend it you.
Re: K&N weber jets
If you fit it under the stock airbox lid you should not have to change anythiing. If you have modified your airbox lid maybe a step up on the idle jet
Brutus
Re: K&N weber jets
Post by Brutus »
Duncati wrote:Hi Leon, kuip stuur ik zaterdag met post...
:thumbup: :thumbup: :evil: :lol: :lol: :D :thumbup: :beer: :beer: :beer: :beer: Stuur nog ff je rekeningnummer, zodat ik portokosten kan overmaken..
Reale
Re: K&N weber jets
Post by Reale »
Brutus wrote:Duncan, I've fitted a k&n and didn't changed the setting led lights. Mine allmost runs perfect..!
In terms of this, I must go with your opinion, because all the others does not seems to match.
jayh
Re: K&N weber jets
Post by jayh »
If the backfiring is on the over-run at lower speeds,and you have no airbox,(just the oval type filter on top of the carby),it is probably one size too large on idles,but this opens a whole new can of worms as you may have to go up a couple of sizes in mains to compensate,or risk creating a lean hole further up the rev range.I know this information is contrary to the traditional,more air flow,must be lean,richen her up approach,but it is based on my experiences with the a similar setup contis/oval k&n/weber.Every time my p750 got backfiring on the overrun,I was rich on idles ! J.
