Hi.
Thanks to who helps me.
The my nick is "cicos68"
I live in Grosseto - Toscana - ITALY
I have a Paso 750 in 1990, In excellent condition, all original, with 20.000 km
My Paso needs maintenance.
Recently I bought the exhaust of Paso 907ie (my holes are) and a reservoir 906 Paso (my loses gasoline).
Both cheaply.
I would like to know if the exhaust and the tank can be mounted on my PASO 750th
From an initial examination, the tank seems to be compatible, but the mufflers are slightly longer.
You can tell me if both are compatible with my 750 PASO?
Thanks to whoever can help me.
Sorry for my English is not perfect, I use google translator to help me.
Thanks to all.
THE PASO 750 will live always
DUCATI PASO for Evere
Haga is great WORLD SBK
cicos68@hotmail.it
Difference muffler and tank con PASO 750 - 906 -907ie
Re: Difference muffler and tank con PASO 750 - 906 -907ie
both will fit.
Can you add your location in your profile ?
- cicos68
Scrivo da Grosseto (Italia)
Help me
Come faccio ad inserire foto nei post e nel profilo?
Grazie
cicos
Help me
Grazie
cicos
paso750 wrote:both will fit.
- ducapaso
Il primo topic del forum 750 dà le istruzioni complete. comunque si tratta di caricare le foto su un sito adatto (flicker, photobucket, o similari) e poi aggiungere il collegamento con la scritta img tra parentesi quadre (c'è il pulsante che lo fa da solo!)cicos68 wrote:Scrivo da Grosseto (Italia)
Help me
Grazie
cicos
Have a look to the first topic in 750paso's forum
ex...Red "smooth" 753349
- Finnpaso
- year: 0
cicos: "Frankie" and "ducapaso" can help You to translate things here! WELCOME!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- cicos68
Thank you. Try to write in English.
Unfortunately for me I use google translator.
Thank you and hello FinPaso
Finnpaso wrote:cicos: "Frankie" and "ducapaso" can help You to translate things here! WELCOME!
- englishstiv
Welcome cicos68
Write in Italian mate - the world is at your fingertips and there are plenty of folk willing to help and translate.
If I am correct in thinking the pipes on the 750 are smaller than on a 907 so you may need to alter the headers with sleeves to fit.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- cicos68
Thank you.
Try
Try
englishstiv wrote:Welcome cicos68
the exit diameter of all Paso headers is the same. Check my header thread here in the 750 forum.If I am correct in thinking the pipes on the 750 are smaller than on a 907 so you may need to alter the headers with sleeves to fit.
