Problems with starting motorcycle RUN/STOP switch
haapai
Post by haapai »
Hello,
I have been having problems with starting my motorcycle. It doesn't matter if it is cool or hot. I can push start the bike with no issues, BUT when I hit the start button I get nothing. I found that if I toggle the RUN/STOP switch it will turn over and start. Of course, you have to be on the RUN selection when you stop toggling. I also found that when the weather was hot the motorcycle will sometimes just cut out. Not a motor issue but I think it is an electrical problem. By no means am I a mechanic so these are the steps I have taken to see if they may fix the problem.
1. Charged the battery and cleaned the terminals - didn't help
2. Changed the fuses - didn't help
3. Took the toggle RUN switch apart and cleaned it. I found hardly any dirt and wear - didn't help
4. I changed the spark plugs - didn't help
The bike does have Japanese electrics (Kokusan). If anyone can point me in the right direction that would be very helpful. I just don't want to be riding and have the bike just quit.
Thanks,
LT
ducapaso
Re: Problems with starting motorcycle RUN/STOP switch
Post by ducapaso »
Make a voltage control on the orange wire on the coils pin while you're starting the engine. you need at least 11v to make coils run.
Whether the kill switch works good and has no impedance (measure this after the plug to the main harness), you should clean the main switch, see the 750paso/faq digest to find the instructions :thumbup:
Have a nice work, and
do you have to crank with kill switch on OFF position and the bike starts when you switch to ON ?
Try to start the engine keeping the Kill switch on ON position. Remove the seat first and if the engine cranks without firing up try to slap the starter solenoid with your flat hand. Try that a few times. If that works change the starter solenoid or try to rebuild it (see download section for instructions). Seems this problem is quite common.
PS: the Toshiba switch from newer Ducs seems more reliable but requires some sort of selfmade mounting bracket as it doesn`t have one.
jcslocum
Post by jcslocum »
You have a voltage drop to the starter solenoid. Take a look at the FAQ for the wiring upgrade thread. It will fix your problem. I guarantee it!
Desmo_Demon
Post by Desmo_Demon »
jcslocum wrote:You have a voltage drop to the starter solenoid. Take a look at the FAQ for the wiring upgrade thread. It will fix your problem. I guarantee it!
+1.....this is how the previous owner of my Paso told me he had to start the bike. I did the upgrade and it now starts with the engine barely turning over. :thumbup:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
haapai
Post by haapai »
THanks for all your feedback. I will try what you have suggested.
LT
Finnpaso
year: 0
Post by Finnpaso »
Later Ducatis use Hitachi unit... :smoke:
907IE -91 red/metal grey
907IE -91 red
paso_rosso
year: 0
Post by paso_rosso »
looks like the wiring upgrade is next for me, too!
i have the 'kill-switch-toggle-to-start-thingy' going on as well.
off to the electronics store!
the wiring upgrade is a really good thing, but in my opinion should be done only after cleaning all contacts, switches etc and making sure the rest of the electrics is ok. It doesn`t solve problems it makes things work by bypassing them. Specially if the regulator/rectifier is not ok and puts out 16V and more at high rpm as mine did once the wiring upgrade could put at least your coils at risk as w/o the voltage drop you will have that voltage also at your coils. Similar thing if you do the relais mod to the headlight.
Still something I would recommend to everyone.
Just wanted to say this.
Desmo_Demon
paso750 wrote:the wiring upgrade is a really good thing, but in my opinion should be done only after cleaning all contacts, switches etc and making sure the rest of the electrics is ok.
I agree with this. I checked the whole wiring harness on my bike before I did the wiring upgrade.....It took forever to go through the wiring harness as thoroughly as I did.....but my bike was an absolute mess when I got it and it needed to be gone through.....BTW, I've put right at 1000 miles since getting it back on the road....maybe I'll start a new thread with a review of the first 1000 miles of my Paso....Hmmmmmm.... :mrgreen:
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Finnpaso
year: 0
Post by Finnpaso »
750 Paso need wiring upgrade with some realys more to function well, but all those are easy to do and 750 Paso have space allaround to put some realys there. One of biggest problems is too small wire diameters in harness and only way to fix that is to put some bigger wires and add some realys to system.... I want to say, that 750 Paso needs 4 extra relays:
one main relay
one for coils
one for low beams
one for high beams
... since those, ill have been happy!
Ok, i forget better starting relay from newer Ducatis (Hitachi unit)... its "MUST thing"
But if guys want to suffer in they lifes, then no need any mods..... Somebody want to keep also they bikes, as "original", but in 750 Pasos case, i think, its stupid to try keep it, like it came from factory...
Sorry my bad english! :mrgreen:
907IE -91 red
paso_rosso
year: 0
Finnpaso wrote:Sorry my bad english! :mrgreen:
problems there are not!
ducapaso
Post by ducapaso »
People all over the world can feel lucky to be able to understand "our" bad english!!!
otherwise, I wander what they might miunderstand, reading our funny mistakes! :-P
persempre907
Post by persempre907 »
Finnpaso wrote:Somebody want to keep also they bikes, as "original", but in 750 Pasos case, i think, its stupid to try keep it, like it came from factory...
It's a matter of points of view.
Many people don't ride their vintage bikes....
Finnpaso
year: 0
Post by Finnpaso »
Ducatis are made for HARD DRIVING in twisty road, (or race tracks surely) !!!!!! Or have i understood "Ducati ideology" totally wrongly? :)
907IE -91 red
