88 Paso throttle cable
Posted: Fri Feb 25, 2022 3:13 am
by Lionel
After finding and receiving a Weber 44 DCNF-113 thanks to Dave73.
I've contacted the local Ducati dealer to get new cables choke and throttle and found they are no longer available. Even googled with no luck. Any one know of a suitable replacement
Re: 88 Paso throttle cable
Posted: Fri Feb 25, 2022 7:06 am
by smartino67
Hi Lionel.
This is from Italy (I assume 906 and 750 fitting the same cable) :
https://www.officine08.it/p75088_cavo-g ... -paso.html
Hope helping you
Posted: Fri Feb 25, 2022 3:46 pm
by murphus
I found mine at https://www.stein-dinse.biz/ . Throttle cable was item #400520157 and choke cable was item #037054130-Z. Both fit/work perfectly and were pretty inexpensive.
Posted: Fri Mar 04, 2022 4:34 pm
by paso750
Posted: Sun Mar 06, 2022 12:46 pm
by Andrew2
smartino67 wrote: ↑Fri Feb 25, 2022 7:06 am Hi Lionel.
Hope helping you
It says it's discontinued from this site.
Posted: Sun Mar 06, 2022 5:57 pm
by randtcastell
I had my throttle cable made up by Motion Pro: https://www.motionpro.com/ I sent in my old ones and in 2 weeks got replacements. Good luck! :^)
Posted: Tue Mar 08, 2022 7:12 pm
by murphus
I'll second Motion Pro. I've bought from them for other projects and always good quality and properly made. Only down side is you can't ride while you're waiting for cables, and if he doesn't have any old ones for patterns ...
