Starting on one cylinder after a long stop
Posted: Mon Sep 21, 2020 8:00 pm
by angelix
it has been a couple of years that it is happening, after leaving the bike in storage for 4-6 months , it will start on one cylinder, then after few seconds it will run properly.
the first time I though an injector was sticking but I am not really sure... any similar esperiences?
Re: Starting on one cylinder after a long stop
Posted: Tue Sep 22, 2020 3:33 am
by higgy
If I had to guess I'd say after months of sitting air in the fuel line
Would be the likely cause or maybe a sticky or shot
Check valve in the pump
Quickest way to figure out fuel issues as Im sure you know is a pressure gauge
And this assumes the more mundane and common issues are not in play....clogged filter, intank fuel lines , funky spark, ground problems,ignition switch...you've been there
Posted: Sat Oct 10, 2020 3:46 am
by higgy
Dont ya just love it when folks post question then dont follow up
Posted: Sat Oct 10, 2020 7:52 am
by Frank.61
Hi Higgy,
I understand you: i assume he's still cranking
(I've had similar experience once due to stale - modern s**t - fuel)
Posted: Sat Oct 10, 2020 6:02 pm
by higgy
Anglelix has been around for for a long time,kinda surprised actually
Posted: Wed Oct 14, 2020 9:47 am
by angelix
sorry guys , I have been working hard finishing a long term project and I am revamping my lab so I lost track of the time.
my 907 is in Italy, I am in the UK, so I will be in position to check it only when I am back there.
when it runs , it does it flawlessly, but it has been already a couple of years that the first start after a long stop (3-5months) is proving somehow "difficult"
Usually it cranks 1 turn and a half and the engine fires, but lately I had a couple of episodes when it starts after 4-5 turns and then rund on 1cylinder for few seconds.
When it happended the first time I got some injector cleaner, this time I just filled the tank with fresh petrol and went for a ride (and what a ride it was 10 months I was not touching the little Elefantino)
unfortunately the issue is not repeiting itself every time so cannot pin point which cylinder is not firing.
I need to find sometime to do some work on it I am doing 500miles a year so there is little wear ,neverthless the years pass by and few things need addressing like the intank hoses and fuel filter, last time I did those was 15 years ago.
by the way, do you know the hose diameter? 1/4" or 5/16"
Posted: Sat Oct 17, 2020 2:26 pm
by Tamburinifan
First thing I`d try is a fresh set of plugs, KISS...
