Rear shock wanted
supak9
Rear shock wanted
Post by supak9 »
Hi, I need a new rear shock for my 907, bit of a long shot but looking for an Ohlins DU508. Any condition, happy to pay for a good one.
The marzocchi is unrepairable.
Thanks, Rob.
1998 Ducati 916
1991 Ducati 907
and some other old oily stuff
thefudginator
Re: Rear shock wanted
Post by thefudginator »
Hi Rob, I have stripped a couple of 750 Pasos and a 906, but not a 907. I do have a couple of Marzocchi's. Not sure if they will fit correctly due to the swing arm and wheel size. Cheers
Paso 750 Yellow in bits
Paso 750 Red x 2 (one running)
Paso 906 in bits.
It is a habit I cant seem to give up!
Post by Tamburinifan »
All shocks compatible 750/906/907.
Pretty sure the marzocchi are re buildable . I had mine in bits for a clean and re-oil ,I'm pretty sure I found out about a rebuild kit after I had done mine
jrhardy
Post by jrhardy »
I have a brand new one off of a 750 Sport that was removed from one of the Ferracci prepared Cortez Replica race bikes. I bought the spares kit years ago from the owner after he crashed (destroyed) the bike at Daytona. If interested send me an e-mail at hardy.john@cox.net. I will have to do some attic excavation but I'm sure it is up there!
A shock from a Sport won't fit in a Paso as the swingarm is totally different. The Paso shocks are interchangeable but the spring rates are different. There are several posts about installing an Öhlins DU508 in a 907IE but its spring seems to be too soft as the tire can rub on the inner fender.
Rudy
Post by Rudy »
I have a marzocchi for sale, price is 100 euro.
Please send repley to info@duc-only.nl and not to the forum
Can send you pictures.
