Rear disc brake
Posted: Tue Oct 09, 2018 10:03 am
by nojapan
Dear Enthusiast,
I would need a rear brake for 750 wheels.
Do I need to look for it only as Ducati Paso 750 or it is compatible with other motorcycles?
Thanks for your help!
Gab
Re: Rear disc brake
Posted: Tue Oct 09, 2018 1:51 pm
by Frank.61
Rear brake is the same as the 906 Paso and 750 sport (NOT the 907 !), but what do you need: disk, caliper, caliper mounting bracket .....?
Assuming you have the master brake cylinder and will buy new brake pads and brake line?!
The caliper, a Brembo P108, is relatively easy to find new or used (ebay etc.).
The disk, new, is a bit more difficult but a good second hand does the job - though you have to clean it or even sometimes you have de-rust it, which isn't to difficult with some sandpaper)
https://www.ebay.com/itm/Ducati-paso-75 ... 547?hash=i
Same with the caliper mounting bracket: relatively easy to find sevond hand, a.o. ebay
Let us know ....
Re: Rear disc brake
Posted: Tue Oct 09, 2018 7:03 pm
by nojapan
Sorry Frank,
just the disc, for the rest I have all.
Thanks for the link but to get the disc in Italy it will cost too much.
I will look locally.
Thanks.
Re: Rear disc brake
Posted: Tue Oct 09, 2018 8:18 pm
by Frank.61
No problem, if you do not succeed try Rudy.
Re: Rear disc brake
Posted: Thu Oct 11, 2018 8:19 am
by nojapan
All goodmorning,
as I did not find new discs at cheap price I decided to ask to a local producer to make it for me.
I already asked to RS BIKES located in Italy several discs and for the Paso rear one he asked me 60 euro + shipping.
I checked into the web and found the following measures:
EXT diam 270mm
INT diam 139mm
CENTER HOLES at 154mm
HOLES diam 6,5mm
Is that correct? I want to be sure before to place the order.
THANKS !
Re: Rear disc brake
Posted: Thu Oct 11, 2018 9:07 am
by paso750
The holes for the screws are 8,1mm as they are M8 bolts.
The inner diameter of 139mm seems too big. I have an adapter for a Marvic rim and it's diameter is 136mm so the disc should be only slightly larger.
Re: Rear disc brake
Posted: Thu Oct 11, 2018 9:26 pm
by Frank.61
Assume it is a stainless steel disk?
To be honest, it's quit cheap especially for a one off .....
I paid for a stainless steel version 137 euro's.
