Stumped. Intermittent poor running issue
Posted: Thu Sep 13, 2018 2:39 pm
As initially described in this post, my bike has begun presenting a peculiar issue when running. Basically it feels like it's either drowning or can't catch its breath. Even in neutral, when I open the throttle, the engine just isn't spinning up like normal, and it even has a bassier note to it. I thought something was amiss in the fueling - so I had the carbs cleaned, and I replaced all the fuel lines & drained the tank (in case there was some water in the fuel).
Rode it to work today and it was fine, until I was almost to work. My trip was some city roads, some backroads, a good freeway blast at ~80mph, then into the city. And the problem started right back up as I got stuck at a light for a couple cycles. It would run at idle, but as I went to give it gas, it just wouldn't rev like usual. And then when I went to get moving, I had to give it a ton of throttle and feather the shit of the clutch ... like I was towing something with it.
I checked the plugs (fine) but haven't done anything with the coils or wires. I was considering swapping to California Cycleworks' high-volt 2v coil kit anyway, but I don't know if this is the issue or not (and I'd rather throw money at the fix first, before an upgrade). Could it be that the ignition system is fine while it's cool, but once everything is warmed up and hot, it just throws the towel in?
I'm stumped. I'm not even sure where to start at this point, because I thought it was fueling-related. Your consideration and input is as always greatly appreciated.
