Speedo drive tab washer threw in the towel ...
Posted: Sun Sep 07, 2014 11:10 pm
by fasterdammit
My bike has gone more miles without a speedometer cable than it has with one, so when the speedometer started showing 0mph at speed recently, I chalked it up to the cable. I ordered a new cable; but when I took the old one off - it appeared to be serviceable still. Curious, but I figured I'd take a closer look when I tore it all apart to clean up the drive and put the new cable in anyway.
Today was that day. And when I pulled the drive off the axle to clean & inspect it ... I got a better understanding of why the old cable still looked ok: the tab on the drive washer was snapped off. Well that's a nuisance ...
I'm hoping this
tab washer @ BevelHeaven will fit. Anyone have another resource, just in case?
Re: Speedo drive tab washer threw in the towel ...
Posted: Sun Sep 07, 2014 11:43 pm
by higgy
see the whole drive on ebay all the time
Posted: Mon Sep 08, 2014 3:25 pm
by paisano
I'm hoping this tab washer @ BevelHeaven will fit. Anyone have another resource, just in case?
that's the same one I ordered and it worked fine.
Posted: Tue Sep 09, 2014 4:09 pm
by fasterdammit
paisano wrote:I'm hoping this tab washer @ BevelHeaven will fit. Anyone have another resource, just in case?
Great! Thanks for the info!
Posted: Tue Sep 09, 2014 11:47 pm
by wcmiller2002
Could be wrong but may have to replace entire unit. This Ducati part is actually reasonable and about $65 US.
Posted: Wed Sep 10, 2014 3:48 am
by Mc tool
Make sure your speedo and cable is well lubed
Posted: Mon Sep 15, 2014 3:28 pm
by JWilliam
Mc tool wrote:Make sure your speedo and cable is well lubed
Ha ha, that always makes me laugh. If you have ever dismantled a speedo drive gearbox for the Paso you will find out that the lube 'nipple' closed by a bearing is a dummy. It doesn't feed to the internal splines. The only way to lube the drive is to remove it from the wheel, take off the circlip and gasket, then dribble oil onto it or soak it in oil.
Posted: Tue Sep 16, 2014 8:17 pm
by fasterdammit
wcmiller2002 wrote:Could be wrong but may have to replace entire unit. This Ducati part is actually reasonable and about $65 US.
Nope. Ordered the part mentioned in my previous post from Bevel Heaven, and replaced it on my speedo drive. It needed a little coercing from a Dremel (wheel tine was too long, and the inner diameter wasn't perfectly round, so it wouldn't fit, but that wasn't a big deal).
There's a spring clip that holds it in place on the drive unit, and there's also a thin seal underneath it (almost didn't see mine when I took it apart).
Good to know about the ball bearing "oil port", JWilliam; I didn't dissect mine far enough to see if it worked or not. Good thing I cleaned & lubed it on the bench.
Posted: Thu Sep 18, 2014 2:15 am
by wcmiller2002
glad to hear. I love being incorrect on stuff like this when a better solution presents itself.
Posted: Sat Sep 20, 2014 11:40 pm
by Mc tool
JWilliam wrote:Mc tool wrote:Make sure your speedo and cable is well lubed
Ah ha ha ha , did you think that was a grease nipple ? that would have been good to watch . I just used gear oil , put it in the top of the speedo cable and a few days later its on the wheel so I know its getting right thru . I just think the less friction in the cable etc the less stress on the speedo drive
