Adjusting tail light sensitivity for front brake?
Posted: Tue Jul 03, 2012 9:57 am
by Mobius
Greets all. I just noticed that my brake light doesn't come on until I am applying quite a bit of braking force - too much to make me feel safe. (The rear brake comes on instantly though - but I do not always use it.)
I have the lever adjusted so that it is as far away from the bar as possible, because otherwise I couldn't get maximum braking without squashing my other fingers; the adjustment screw is all the way in.
How can I set the brake light so it comes on as soon as brake just very lightly on the front? Cheers!
Re: Adjusting tail light sensitivity for front brake?
Posted: Wed Jul 04, 2012 12:15 pm
by JWilliam
Can't be done can it? The switch is hydraulically activated and is part of the pipe union above the front wheel. I haven't seen any form of adjuster although I expect the switch can be replaced.
Posted: Wed Jul 04, 2012 7:44 pm
by paso750
Depending on your brake pump you can add a brake light switch. If you don`t have the two holes I guess you can make them yourself ...
Then just disconnect the pressure switch and wire up the electric switch. It will react sooner and faster.
Posted: Wed Jul 04, 2012 10:42 pm
by Fraser
Mobius,
First up remove the push on wire connectors at the hydraulic switch and give everything a really good clean. This might help the connection to the tail lamp. If it does not help, then the hydraulic switch is failing. They are still available from your Ducati shop, but as usual they are a bit pricey (have replaced it twice over the years). Last time I started looking for an automotive substitute (Repco etc) but the diameter was too small, but did not persue as at the same time I changed the brake calipers and ended up buying a new master cylinder/lever which came with an inbuilt micro switch.
Fraser.
Posted: Tue Jul 17, 2012 10:44 am
by Mobius
Thanks Gents. I'll try fixing first. Cheers!
