ignitech
Posted: Fri Apr 06, 2012 3:53 pm
by samandkimberly
I'm in the process of buying some Ignitech TCIP4 ignition units for another bike, and I realized that with the next purchase my pricing on Ignitech products may get pretty good. So good, in fact, that I'm thinking of buying one of these:
http://www.ignitech.cz/english/ignijet/ ... ducati.htm
This would come with the correct connector to plug right into the 907IE harness, replacing the original ECU, so swapping back and forth during tuning would be possible. Looks pretty cool. Cost would be under $500.00 delivered, which is not at all bad.
Anyone interested? I'm just putting out feelers right now; I wouldn't be pulling the pin on this project for a month or two.
FWIW, The programmable ignitions - TCIP4 - cost me about $160 with shipping. There's lots posted on these in the Paso forum.
Sam
Re: ignitech
Posted: Sat Apr 07, 2012 12:57 am
by angelix
samandkimberly wrote:I'm in the process of buying some Ignitech TCIP4 ignition units for another bike, and I realized that with the next purchase my pricing on Ignitech products may get pretty good. So good, in fact, that I'm thinking of buying one of these:
Sam
Are you sure you can fit the IGNIJET2007 on the 907? they are two completely different beasts...
Re: ignitech
Posted: Sat Apr 07, 2012 3:22 am
by samandkimberly
That's subject to verification, but it looks like yes. The systems have essentially the same I/O and ignitech has made and installed them with earlier connectors.
Sam
Re: ignitech
Posted: Sat Apr 07, 2012 9:37 am
by Derek
The Ignijet2007, as you can see from the pic, is fitted with connectors for the IAW5.9 and IAW5M ECU as fitted to my ST4s and most of the most 2001 on Ducatis until the Seimens ECUs on the latest bikes. Now with the right connectors I would imagine that it should be possible to fit it using the sensors on the 907. The only thing I'd be concerned about is that the 907 uses 2 engine position sensors, one on the flywheel for the crankshaft position and one on the jackshaft to determine the phase, whereas the later bikes have only one engine position sensor on the jackshaft which is used to determine both crank position and phase. I supose Ignitech will know whether this will work or not.
Re: ignitech
Posted: Sun Apr 08, 2012 12:25 pm
by Tamburinifan
+1 on Derek, won´t fit.
Fr their site:
IGNIJET 2007 DUCATI
Programmable unit for injection and ignition control for Ducati bikes (Magnetti Marelli units IAW5.9 and IAW5.AM)
Re: ignitech
Posted: Sun Apr 08, 2012 3:48 pm
by samandkimberly
Tamburinifan wrote:+1 on Derek, won´t fit.
Fr their site:
IGNIJET 2007 DUCATI
They have also built replacements for IAW435/P8, with no problems. I've been exchanging info with them and they seem to know their stuff. That said, I'm still on the fence on this one. The programming environment seems nice, though, and I've heard nothing but good about their quality.
IF I go ahead I'll probably just buy one and be the 907 Guinea pig.
Sam
Re: ignitech
Posted: Wed Apr 11, 2012 2:02 pm
by Tamburinifan
They are knowledgeable guys, made me custom
wiring & timing curve f an ol Suz f a friend f e.
I run a WM P8 on mine now so just go for it!
