750SS pistons into the Paso 750 engine
Posted: Fri Nov 04, 2011 11:15 am
by gipsy8888
do the mid-90's 750SS pistons fit into the Paso 750 engine? of course
the Bore size is the same, but what about the Crown and the wrist pin?
Thanks !
:thumbup:
Re: 750SS pistons into the Paso 750 engine
Posted: Sat Nov 05, 2011 9:50 am
by paso750
The conrods are the same, you`ll see that if you check for webshops or catalogues listing aftermarket parts so the pins should be the same (18mm if I remember well). The crankshafts are the same as well.
The crown is different as the 750 Paso and Sport have a higher compression than Supersport or Monster.
This is what I know.
Posted: Mon Nov 07, 2011 12:22 am
by jklnhyde
I'm a bit confused.
The Paso 750 manual claims a CR of 10:1; is this correct? At several sites I've seen specs as low as 9.3:1 for the Paso 750/ F1 750, and 9.5:1 for the 750SS of the same years. If the posts on this site are correct, then the Paso/F1 have the higher (10:1) CR and the SS/M, lower CR. Ok, I got it. So, are the two identical sets of domed pistons sitting on my bench the stock (higher CR) Paso/F1 pistons or are they higher (than normal) CR for the Paso/F1...how do I tell them apart? One set was already in the motor, the other I bought as "high-compression Paso 750 pistons". Did they mean 'higher-than-stock compression, or were they identified as "yes, they are high compression pistons, beacuse they came from the Paso/F1, sir."
Input please.
Posted: Mon Nov 07, 2011 9:39 am
by paso750
jh I`ll reply in your thread.
