Weber Question- Float needle
Posted: Wed Jun 29, 2011 6:18 pm
by Corse
Having stripped down the carb I'm having difficulties removing the float needle, it unscrews ok but hits the float bracket , it looks like the thin float shaft is pinched into the housing on one side, does it need to be forced open to remove the shaft?
Re: Weber Question- Float needle
Posted: Wed Jun 29, 2011 7:08 pm
I used a thin nail and a rubber hammer to push out the floater axle. If you push it out a bit you can grab it with some pliers and remove it and the floater.
Posted: Wed Jun 29, 2011 7:20 pm
by Corse
Thanks I thought I would have to be a little brutal with it but wanted expert advice!
Posted: Wed Jun 29, 2011 11:01 pm
by higgy
also,it only comes out from one end,motion is from the solid end to the spit end, If you do it backwards you will need a new carb top,assuming you can find one so do pay attention
Posted: Thu Jun 30, 2011 2:41 am
by Corse
Posted: Thu Jun 30, 2011 9:21 am
oh no, sorry to hear that. On which side did you tap ? The split side holds the point of the axle so that is where you should have tapped with a nail. It says in the Weber manual "Always remove pin through solid boss not split one". Should`ve mentioned that.
The SS airbox won`t fit into the frame so you would have to use filter pods or modify a Paso airbox. What you need is described in the FAQs. I.e. accellerator grip + cables, carb manifolds from a 750 SS or Monster. The ones from a 900 will work, too if you don`t use an airbox as they are longer so the carb will stand slightly twisted. You can try the carbs jetting. The one of the 750 is a little different but at the end the jetting will depend on your airfilter setup, exhaust etc.
Posted: Thu Jun 30, 2011 2:00 pm
by Corse
Thanks but I went the other way with the nail..
I see that the manifolds are indeed longer from the 900ss, so if I use those carbs what type of airfiler works best if no airbox can be used? just a regular K&N
I also have the Bollenbach 750 that I bought earlier in the year, I need to look at that setup...maybe today
Posted: Thu Jun 30, 2011 9:00 pm
by Fraser
Corse,
Uni Filter do some great aftermarket filters/pods to suit the SS carbs.
http://www.unifilter.com/online%20catal ... ucati.html
That's what I use, they are good.
Fraser.
Posted: Thu Jun 30, 2011 11:28 pm
by higgy
It is always best to support the holder with a block of wood,or learn to cuss in Italian.....guess I should have mentioned that,but then again it does not take a lot of force to change it live and learn ducatista
Posted: Fri Jul 01, 2011 8:14 am
and you should have mentioned that this is when assembling not removing the floater.
Here`s a complete Weber on ebay. Rarely some are offered for less but mostly they are more expensive
http://cgi.ebay.com/ebaymotors/DUCATI-P ... ccessories
UniFilters are nice, I have some, too. The only thing I don`t totally like about them is that they are made of a single layer foam. Some others have a double ply foam with a rough and a fine pored layer which may filter fine dirt better.
Posted: Sat Jul 02, 2011 3:26 am
by Corse
I was gentle with it too and took the advice to go that way! oh well its a good excuse to dump the weber anyway...
I noticed my Bollenback is fitted with 38 FCRs I have not ridden it yet and wonder how much better it will be?
