Clutch problem?????
Posted: Sun May 01, 2011 7:16 pm
by Vince
Hi` I gotta a question for you guys I was on a nice little ride yesterday and the bike was running great but all of a sudden I noticed my gears were not working properly I had use force to get it in the next gear? Could any of you tell me might be the problem i took the main cover off to see if i had a bad bearing it looks decent :? Vince
Re: Clutch problem?????
Posted: Sun May 01, 2011 7:37 pm
by fredskidoo
If you feel that the clutch isn't engaging or dis-engaging correctly or consistently I suggest that you start with bleeding the fluid clutch system - in it's entirety . . . You will find a wealth of information and experiences involved with the Paso's "bleeding clutches" right here - dig in :)
http://forums.ducatipaso.org/search.php ... mit=Search
Posted: Mon May 02, 2011 11:16 am
by jcslocum
Fully flush the fuild with new as step #1. That should help if the fuuild was contaminated with water. Once hot that water boils out of the fluid and creates a problem disengaging thet gears fully.
