Couple of questions
Posted: Sun Jan 02, 2011 8:30 pm
by 2vtwin
1. My recently acquired 907ie was missing the Odometer reset knob/cable. I found and purchased NOS, but not sure how it routes. When I'm sitting on the bike the hole in the faring trim is on the right, cable does not appear to be long enough to go over to the right side, should the hole in the fairing trim be on the right or left?
2. I have brake lights but no tail lights, put new bulbs in, checked the fuses, no luck and the left turn signal flashes faster than the right. Behaves like something is not completing the circuit. Just a thought are the rear turn signals also running lights? Thanks - Gene
Re: Couple of questions
Posted: Sun Jan 02, 2011 8:44 pm
by pasolloyd
Gene,
The hole for the reset knob goes on the left.
The turn flasher requires a minimum load to flash correctly. Mine has a pair of 21 W bulbs per side - one at the front, and one at the rear. The tail lamps are type 1157 I believe, which means they serve as tail and stop. The tail and stop circuits are separate back to the fuse so you just have to trace back to the fuse using a meter. Check the wiring at the left handlebar switch especially if you don't have daytime running lights. The integrated turn/tail lamp uses separate bulbs within the housing for turn and tail/brake. It is possible however, to have an integrated lens on a US style tail light assembly.
Lloyd
Posted: Sun Jan 02, 2011 10:51 pm
by 2vtwin
Thanks. The cable does not seem to want to work in a big loop but now that I know that it goes on that side I'll fool with it. I have two bulbs in the assembly and they are double filament, with a yellow wire in one side and red/back on the other side. The test light shows I have power going back to the red/black side when I apply brake but no power to yellow side with or without brake. The one bulb I could read was a 2158, so I put two of those in. I'll trace back the yellow wire and see what if find. Thanks again - Gene
