Page 1 of 5
Technical (non Paso) 1990 900ss
Posted: Mon Sep 27, 2010 6:53 am
by giocast
Hi to you all - I haven't got a Paso yet, but it isn't for the want of trying, just missed a 750 non-runner about 4 months ago. I do have above though, which you know shares quite a few bits.
My problem is that I haven't managed to get engine running yet, despite rifling through absolutely all the usual suspects.
My symptoms are:- on churning to start engine fires immediately but it's a backfire as though timing is too advanced (but it isn't). Occasionally it fires conventionally but i've stopped trying now as the regular kicking-back is not going to do the starter and sprag any good.
Just to let you know this is quite a baffling one - starter churn speed is good, both compressions are good (150 p.s.i.), am getting a regular spark on both plugs (stronger since I cleaned plugs and earths), belts are good and timed correctly, ignition is single point pick-up like some Paso's and gap is correct, On start churn, say around 3-500 rpm, connected strobe shows spark aligns with TDC on both cylinders (I mark them on the clutch!), I am using fresh fuel, Weber 44 has been overhauled recently, and I have also checked jets - have also been using Bradex Easystart occasionally to confirm no starvation (coughs is the same with or without).
I am starting to scratch my head as this is probably a 'can't see the wood for the trees' moment - can anyone help with any fresh suggestions? - I also have Digiplex 442A as per 907, but as spark seems consistent I could be barking up the wrong spruce.
Also, can anyone confirm that timing is correct to be aligned at TDC when engine is turning that slowly? - I looked at ignition advance graph and it seems quite reasonable.
I have already corresponded with Gerhard, who has an obvious Paso Passion! Many Thanks in anticipation.
Re: Technical (non Paso) 1990 900ss
Posted: Mon Sep 27, 2010 10:04 am
by higgy
What spark plugs are you using?
Posted: Mon Sep 27, 2010 10:21 am
by Tamburinifan
Fresh petrol in tank?
Good fuel filter?
Adequate amount of petrol flowing to carbs, sparks getting wet?
Running/starting before this normal?
Posted: Mon Sep 27, 2010 1:07 pm
by giocast
Hi Higgy and Tamburinifan - Plugs are correct NGK '8's and yes, plugs are at least getting wet. Unfortunately I can't comment on how it came to 'not run' as bought it like this. I checked the two airscrews today both wound in and sadly someone has 'leaned' on one and partially stripped thread.. Have set both mixture screws to two turns out. As I said, I am baffled at the moment. Just had a hunch while typing and I think I might be onto a winner... I have depleted sense of smell due to a virus - when I emptied the crankcase of oil to check alternator nut etc, I thought it was a little thin - i've just gone and stuck me snoz right in it, and it made my eyes water! The only other thing I could think of that would explain the early firing symptom (other than being advanced) was if the throttle was cranked open too wide.. (or in my case flooding possibly due to hardened gum on float needle valve) Being a downdraught the overflow pipe (if there is one?) wouldn't get much of a chance would it? I'll get back to you after I put cover back on etc. Thank you for taking the trouble you two.
Regards
Posted: Mon Sep 27, 2010 1:57 pm
by angelix
have you tried swapping the plug cables ?
it sounds like you are firing the cilinders with the plug cables fitted the other way around.
Usually the coils are Marked "V" for VERTICAL, "O" for Horizontal, so it is easy to check if they are correct, however sometimes it happensa that the wiring coming from the Digiplex/Modules to the coils has been swapped around by mistake...
Posted: Mon Sep 27, 2010 2:11 pm
by higgy
Fuel in the oil would certainly give you problems if the float valve is stuck open,on the other hand if it was stuck closed oncce you drain bowl it wouldn't fire at all. Stuck floats are not uncommon on any carb, and with the weber especially it would go right down the cylinders
Posted: Mon Sep 27, 2010 2:38 pm
by giocast
Thanks Angelics, but no, I centre pop the two TDC's on the flywheel side and then put an 'H' and a 'V' next to them - easier to see the strobe light there as well. I'm hoping it's the flooding that's the culprit but won't be able to test it until i refit cover (had to order a new nose bearing so am changing g/change sleeve bearing and oil seal as well - came to about a tenner from Ducati UK!
Posted: Mon Sep 27, 2010 8:02 pm
by duc907
If you are spraying starting fluid(ether) in the engine and its not running or turning over you have a spark problem.
Posted: Tue Sep 28, 2010 9:59 am
by giocast
Thanks for your input duc 907,could you narrow it down a bit?
Posted: Tue Sep 28, 2010 1:32 pm
by angelix
giocast wrote:Thanks Angelics, but no, I centre pop the two TDC's on the flywheel side and then put an 'H' and a 'V' next to them - easier to see the strobe light there as well. I'm hoping it's the flooding that's the culprit but won't be able to test it until i refit cover (had to order a new nose bearing so am changing g/change sleeve bearing and oil seal as well - came to about a tenner from Ducati UK!
OK,
provided you are 10000% SURE the sparks are correct and in fase with the rest, what you can do is the following:
- remove the tank and airfilter, disconnect completely the fuel line and dry the carburetors
- remove the spark plugs; crank the engine for 5-10 seconds x 3 - 4 times to clear the cilinders.
- install NEW Spark plugs, & connect the electrics the "correct way".
Once you have done all the above take a normal 50ml siringe full of petrol, put some in each (10-15ml per cilinder) of the two venturis while keeipnt the throttle Wide open.
do not use anything but the sirynge, with it you know exactly how much petrol you are putting in.
then wait 10 seconds and crank the engine for few seconds...at this point it should start and run for 2 -4 seconds.
this way YOU KNOW that it is not an electric problem.
once you hear it is running, you can repeat the starting procedure 4-5 times just to get it warm
At this point you can FILL the carb using the SIRYNGE ( do not use the fuel pump so you avoid overflowing; the best would be using an auxhiliary tank for testing (you can find them on ebay) and feed the carbs by means of gravity.
IF BY ANY CHANCE you get backfire in the Airbox, don't get scared and put off the fire with a damp cloth, just make sure you do not have any petrol or open cans close where you are doing your testing and keep the area well ventilated.
I still believe you swapped the cables, the simptoms are exactly the same that I had when I assembled my engine and fired the first time (FCRs & Kokusans , tho')
Posted: Wed Sep 29, 2010 9:52 am
by Mc tool
I was just thinking about the Xed plug wires too !. The only thing I can offer is that my paso runs like a bag of hairy arseholes without the airbox cover. Im thinking that these duke motors will quiet happily start and run on one good pot so what ever is stopping yours is common to both pots . Is the digiplex getting enough voltage , especially while cranking ?Have you checked cam timing with a degree wheel, or just the timing marks provided ? If the latter is the idle shaft correctly timed where its geared to the crank ? . Fuel in the oil would indicate ( to me anyhow ) that its getting heaps of fuel its just not able to burn it.The fact that your regularly getting backfires sez its getting fuel , spark and seeing as how its got good( ish ) compression..... it sounds like a timing issue , assuming that the fuel is fresh ( just coverin my ass here
Lookin forward to hearing what it is , good luck
Posted: Fri Oct 01, 2010 12:18 am
by giocast
Thank you Mctool - that is another check to do (Digiplex voltage) and I will check accuracy of cam timing just for the pleasure of finding out. I can't report anymore yet as haven't got service bits in post yet (plus just come out of hospital
Will certainly post soon. All the Best
Posted: Sun Oct 03, 2010 5:29 am
by Mc tool
I meant to say that the timing of the idler shaft would only be an issue if it had been apart since last going. Sorry to hear you have been crook, ( I know the feeling )
Posted: Tue Oct 05, 2010 11:59 pm
by giocast
latest update :- All back together after checking nuts at both ends of crank, so tried a 'dry carb' start attempt with Bradex only and result is almost the same, i.e. big kickback.. While stripped, I took the trouble to double check/triple check all of ignition and valve timing and everything is correct. There was one difference - engine did fire about 3 times before petering out on one occasion. Allthough I was getting pretty consistent readings whilst using strobe I think I will have another look at the Digiplex unit and check out the vacuum sensing input..
Posted: Wed Oct 06, 2010 9:26 pm
by Mc tool
