St2 Engine
Posted: Mon May 31, 2010 7:55 pm
by 93IE
I was wondering if an ST2 engine will bolt into a 907. I've a few on ebay that are reasonably priced compared to an overhaul of a 907 engine. Just curious
Preston
Re: St2 Engine
Posted: Tue Jun 01, 2010 8:46 pm
by biffo
hi preston one you would have to do is drill and tap the front cylinder barrel for the front engine mounts biffo
Re: St2 Engine
Posted: Wed Jun 02, 2010 1:27 am
by Tamburinifan
Dunno fitment physically,
but it uses a different ECU which means a lot of different wiring issues etc.
Re: St2 Engine
Posted: Wed Jun 02, 2010 8:02 am
and machine the rear part of the engine to fit the Paso swingarm as it is narrower.
Re: St2 Engine
Posted: Thu Jun 03, 2010 3:03 am
by 93IE
I didn't think about all of the electrical that would need to be redone. I think I'll just go thru the 907 this winter. I am sure it needs valve guides and seals. I have 29K miles on it now, and it it uses about 1/2 quart every 1K miles. On the average, about how long will it go before it needs the bottom end looked at?
Preston
Re: St2 Engine
Posted: Fri Jun 04, 2010 3:44 am
by du907
I had just over 50,000 miles on mine before I had the engine rebuilt. The alternator rotor cracked and siezed the engine at a track day. Metal particles went all over the inside of the engine. So while you are at it you should have it balanced and blueprinted, the bearings shimed, that plug in the crank fixed, and maybe replace the gear set that turns the shalf the valve belts are driven from, and the heads flowed and valve guides, etc.
Mine cost about 4K USD.
Re: St2 Engine
Posted: Fri Jun 04, 2010 11:00 pm
by ducbertus
I'm gonna swap a ST2 engine in my 907 the winter ahead.
I've the engine in the States 2 years ago for € 400. the required ECU and wire looms are present. A set of Carrillo's is waiting to be assembled.
still there are a lot of parts to change before adapting the rear fork and rev counter. Butt we'll see.
Bertus
Re: St2 Engine
Posted: Fri Jun 04, 2010 11:56 pm
by Tamburinifan
Butt we'll see.
Do keep us posted, interesting!
Re: St2 Engine
Posted: Sat Jun 05, 2010 4:44 pm
by Finnpaso
Re: St2 Engine
Posted: Sun Jun 06, 2010 11:29 am
by ducbertus
I will Annti, I will.
this has to become my winter project after finishing my new lathe and mill,
to machine the parts.
Bertus
Re: St2 Engine
Posted: Sun Jun 06, 2010 4:40 pm
by Finnpaso
Also i am dreaming lathe in my garage! "Others" i have...
Very often need to make some small parts from allkind materials and lathe would be great...
Re: St2 Engine
Posted: Sun Jun 06, 2010 10:49 pm
by Tamburinifan
Rev counter tunnel is the smallest problemo, I`ve dunnit,
the ECU-starter button-sensors etc is the challenge....
Re: St2 Engine
Posted: Mon Jun 07, 2010 10:52 am
it might be out of the question but you can do a carb conversion with the ST2 engine. A friend of mine did that with a set of Keihin flatslides. All you need are pick-ups with mounting bracket, flywheel and ignition modules from a SS, 906 or other. If the engine misses the mounts for the pick up bracket, these need to be welded in.
Re: St2 Engine
Posted: Mon Jun 07, 2010 11:15 pm
by Tamburinifan
Cool idea.
Actually,
since the Ignitech TCI-P4 can handle 900ie & 1000ie ignition,
it would work f ST2 too. And no pickups would be needed.
You`re giving me new ideas, G, ..... Just need a solution f engine mounts.
