fork seals ?
Posted: Sat Dec 12, 2009 11:13 am
by snakey
does anyone know the size and or part number for the fork seals on a 750 sport - the forks are the standard ones - according to the manual- MIBB.
Pete
Re: fork seals ?
Posted: Sat Dec 12, 2009 3:49 pm
by ducinthebay
Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
Re: fork seals ?
Posted: Sat Dec 12, 2009 10:04 pm
by snakey
ducinthebay wrote:Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
thanks for that - i think i have located some.
sizes that i have been given are 40x52x10 with part no 754905(
http://motorcycleproducts.co.uk/catalog ... 43795.html )
Pete.
Re: fork seals ?
Posted: Sun Dec 13, 2009 3:40 am
by ducinthebay
If you have a choice of makers of seals, Fruendenberg NOK makes some of the best ones. My local suspension shop uses them when ever they can.
Re: fork seals ?
Posted: Tue Dec 15, 2009 5:47 pm
by whitepaso
For what it's worth, when I replaced the seals in my M1R's last year, they were readily available from Parts Unlimited for a fraction of the cost from Ducati. When they arrived, they were from the same manufacturer as the original seals I removed!
A dealer should have both the seals and the wipers. For seals all they need to know is the size, which is on the top of the seal
Re: fork seals ?
Posted: Fri Apr 30, 2010 5:28 pm
by snakey
snakey wrote:ducinthebay wrote:Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
Pete.
These are completely wrong, too loose a fit and have fork oil squirting out of both legs now. I have tracked down some genuine ones at
www.windwave.co.uk part no :- 528053 size 40x52.2x10/10.5
