Page 5 of 5
Re: Technical (non Paso) 1990 900ss
Posted: Fri Oct 11, 2013 6:02 pm
by giocast
I was tempted to elongate or reposition the single pick-up of the standard system Phil but it seemed like sacrilege to do that to the engine casing plus as you say, still no facility/much harder to fine tune the settings.
Posted: Fri Oct 11, 2013 6:20 pm
by ducinthebay
Just to confirm all the parts that you had to change to replace the Digiplex system with the Kokusan system.
- Pickups and pickup plates attached to the cases. Along with wire harness. Cap off the old sensor hole on the cover.
- Flywheel for different timing marks
- Exciter boxes that replace the old Digiplex box.
- Assorted wiring changes to get power and signal to the right places. (follow a later model wire diagram)
A good bit of work, but certainly doable, and for the most part a bolt on conversion, is that right?
Just want to get your perspective so that I am prepared for when I have to make the change, or someone else on the list gets frustrated with the Digiplex.
Posted: Wed Jan 15, 2014 3:18 am
by giocast
I don't think you have left anything out there, and yes there is provision to fit all ignition parts to the engine without modification as Cagiva wisely covered all options with the crankcases - you have probably seen the blanking plate for the clutch pushrod option as well. You just need to find a home for the exciter boxes as I think you said. If you are using an SS/Monster as a donor then the brkt for housing these and the coils is adaptable
Posted: Thu Jan 16, 2014 12:14 am
by Maico88
It is not my intention to hijack this thread, but after reading Glocast's post I have to ask. Can a 750 Sport or Paso be easily modified to accept the clutch setup from a later style slave cylinder.
Posted: Thu Jan 16, 2014 9:33 am
by fester
Maico88 wrote:It is not my intention to hijack this thread, but after reading Glocast's post I have to ask. Can a 750 Sport or Paso be easily modified to accept the clutch setup from a later style slave cylinder.
Short answer in no and the 900 which is closer to the later bikes is no joy as well. Even though the 900 has the blanking plate where the slave is we do not have the hole in the side casing or the hollow input shaft or any of the seals. You would have to pull the motor down and replace the cases and gearbox bits. This was high on my wanting to do list but it's been shot down after research.
Posted: Thu Jan 16, 2014 12:01 pm
by Maico88
Posted: Thu Jan 16, 2014 7:32 pm
by giocast
as fester says, sadly it's only the crankcases that are universal clutch-wise here.
