I'll start by saying what a great bike the Sport is.
First some fresh fuel.
I decided to leave the seat cowl off for now for two reasons. One, I need to get the seat to sit a bit lower so it's not putting pressure on the two tabs that slide into the ducktail and two, Italians must have small arses because it's a tight squeeze for me to fit on the seat with it on
Anyhow, seeing as the tyres are 6 years old even though they have never turned a wheel I thought I would just cruise down the freeway a bit then turn around and come home. Wrong. This thing is great. So good in fact that I kept riding. In fact I took it up the local twisty pass and down the next one although at a steady pace until I'm sure the tyres will be ok. So far they are sticking well with no problems at all.
To say I'm impressed with her first outing in 13 years is an understatement. She handled much better than I expected with the 16" rims front and back. I will admit the roads were pretty good and I didn't push it at all but first impressions were great. It tracked beautifully through corners and held it's line fantastically. Besides tyre choice I'm not sure why you would want to change the wheels.
This was the start of the twisties so I hadn't tried to lean it over yet but by the end the tyres seemed to be ok. I'm still going to be cautious for a while though until I feel confident they're still good.
Now onto the throttle response. It was near perfect. Much better than my old Paso. The previous owner was a workmate and a motor mechanic and I knew he had played with the carb to get it running right and I must say he's done a fine job. It ran near faultlessly with only the occasional stumble off throttle around 3,000 rpm but so small that I wouldn't even mention it. No worse than some Delorto Ducati's I've ridden and far better than my old Paso which just goes to show that they can be made to run correctly. I was surprised to say the least.
The other surprise was how comfortable it was. I rode for 1 1/2 hours and could have kept riding. The suspension was firm and probably wouldn't be so good on rough roads but was fine on smooth stuff.
I can't wait to get these tyres over a bit more and see how it really handles
