Page 2 of 2
Re: Norway callling! New member.
Posted: Sun Apr 01, 2012 1:09 am
by Andrew2
Your bike looks fantastic Reo.I especially like the single seat.
Andrew
Posted: Sun Apr 01, 2012 6:07 pm
by reo
Andrew2 wrote:Your bike looks fantastic Reo.I especially like the single seat.
Andrew
Thanks. I agree
Best regards, Rune.
Posted: Sun Apr 01, 2012 6:26 pm
by reo
Hi.
I've used a couple of hours this morning and moved the coils, and turned the horizontal carburetor. For the first time the bike started on the first attempt and went to idle without stopping. Do not know why, but that was the result.
I have not tested driving yet , thought I'd listen to you experts on this forum first.
Will there be any problems with the carburetor placed in that angle of the cylinder?
Before:
Now:
Appreciate input from members because carburetors are not my forte.
Best regards, Rune.
Posted: Tue Apr 03, 2012 3:38 am
by ducinthebay
For any motor, a bigger aircleaner is better. The ones you have are rather short. I use ones twice the length after I added elbows.
I see that you have the big velocity stacks on the carbs already, and also don't have accelerator pumps on that version of carbs. Don't add a quick turn throttle to that setup, it will bog when you whack the throttle open. (go too lean temporarily)
I think the carb angle is a bit too severe. According to the Dellorto manual, 40 degrees is the max installed angle. I can't determine the angle you have, but venture to say its more than 40 degrees.
http://www.ducatimeccanica.com/dellorto ... rto_2.html
You may run the main jet dry at times with the current setup. The Keihins can run at that angle, as they are designed to be a down draft carb, but not the Dellortos, they are side drafts and can't tolerate that angle. But if it works for you, then its good.
p.s. A few things to sort out.
- The vent tubes from the carbs are attached to eachother, and should go to atmosphere.
- Also, one of the nipples on the bottom of your tank is blocked off. Its either the return for the carbs, or the vent for the tank, which should be vented to atmosphere. Either way, it should be utilized.
Posted: Tue Apr 03, 2012 8:14 pm
by reo
ducinthebay wrote:For any motor, a bigger aircleaner is better. The ones you have are rather short. I use ones twice the length after I added elbows.
Hi.
Thanks for the answer. I have tested now, and it matches what you suspect. I did not get enough fuel during heavy acceleration, so I have now turned back carburetor. I also measured the angle, and it was a few degrees above the recommended.The tubes from the carbs and the nipples( which is the return from the tank) has been like this all time, but it does not mean that it is correct.
I will look at this as well. I have also ordered 90 degrees elbow to air filters.
Best regards, Rune.
Posted: Thu Feb 28, 2013 8:28 pm
by serious black
Hei Rune. I live in Stavanger and picked up a 750 Sport engine and good GiaCoMoto exhaust for not much money last year. It has the complete wiring, Ingintion, regulator, carb and airbox and needs a good home. Are you interested?
