New Paso owner
Fubar
New Paso owner
- fasterdammit
- DesmoDog
Re: New Paso owner
You probably already know this, but those carbs have accelerator pumps in them so when you open them up they squirt fuel. There is an adjustment on how much fuel they dump, but it sounds like you have it worked out already?Fubar wrote:... With the mixture screw set at 1.5 turns out per SKINS suggestion I got the Paso to idle steady but if you blipped the throttle hard from an idle it had a large flat spot but if you ran the ticks up to around 1400 then give it a twist it took off. Anyway I ran the front carb a little leaner at 1.25 turns in and the rear at 1.5, fixed it idles great and revs cleanly.
-Craig
Fubar
- Finnpaso
- year: 0
Cute Paso!!! But, have U any pics from U wife????
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
pikey
- jcslocum
The 750 pulls pretty good for it's size and age. It will never have the deep torquey feeling of a 1400cc motor. The Paso is a great combination of power and handling but it is 20 years old! If you want elbow pulling acceleration, go to a local dealer and try out a Multi 1000 or Monster 1000. The new dual spark motor pulls like a tractor and will pull like that all they way to the red line.
