dodgy lights desmodave
desmodave
- year: 0
Can anyone help with my problem wich is when i pull the brake lever the parking light comes on already ive nearly gone over one car bonnet but now its failed the mot so missing the summer so far! im running a electrex reg does it bypass the wiring on my 89 750 paso?
- Finnpaso
- year: 0
Pull brake lever and parking lights came on ????
Sound, like earthing problem, like many older Fiat cars have, when not enough good earth in system.... Check those first!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Rogero
The world of Paso electrics is wonderful. I recently had a brake light which wouldn't go out and only one bulb working in the rear cluster..
Check the connections, taket the bulbs out and make sure all is dry. I did a bit of squeezing and drying and both the above problems were cured.
A squirt of WD40 here and there helps too.
Has yours got wet recently?
Rogero
1992 "Red" 907 I.E.
1992 "Red" 907 I.E.
