Hello All,
Just noticed I dont have the part number 037740065. Swing arm jaws! My axle bolts are directly onto the swingarm.
Could someone measure theirs so I may try and get some made, or if you know of a pair for sale....
CHeers,
Pete
Missing swing arm jaws
Re: Missing swing arm jaws
Can measure mine tonight after work no prob.
The jaw is 75mm long and 6mm thick on the flat side and 5mm thick on the top and bottom wings. The swing arm height is 50mm neat so it needs clearance on the internal dimension to fit over that. HTH
Thank ya kindly. Lamenting my woes to a fellow Ulysses member got the phones a ringin a set has been located. What's a few grey hairs hey? The carb is almost finished, got a new float delivered today but need to wait for a choke cover gasket, not in the refurb kit.
Right, got those bits. Got the carb refurb and a new float, waiting on a gasket for the choke cover. Then that will be all done.
