engine problem
devildad
engine problem
I get a miss or burp, usually at low rpm. Will stall bike at idle. Any thoughts?
devildad
- Skins
I've never worked on Mikunis (I have DelOrtos) but they probably also wear mostly at small throttle openings. Have you read my carb tuning advice in the 750 FAQ in 750 Discussions?
Also, Paul (that's his member name) has posted pics of how the throttle stop screw in DelOrtos makes a wear hole in the side of the slide, which causes big problems.
pope
devildad
pope
Here is their websight. I believe that you can get them through other aftermarket suppliers too:
http://www.dynaonline.com/english/coils.htm
I've go a picture of mine mounted up I'm pretty sure I used two single output, green, 3 OHM. If you send an e-mail address I'll send the picture to you. They make a lot of difference especially when starting, chopping the throttle and acceleration.
Doug
Doug
