750 sport dropped the primary drive sprocket
Re: 750 sport dropped the primary drive sprocket
Thanks for the lead G my local Ducati store did'nt stock them anyway and would have to order them in.
- ducinthebay
A pretty lame dealer that doesn't stock a sprocket retaining plate. A pretty common replaceable item. If you have a Ducati with more than 30k on the clock, you are probably due for one. If you own a Ducati made in 1998, you had best get a new one anyway. Bad batch that year. Too soft. Lots of ST sprockets walked off the job like yours did. Not a lot of Ducatis had high mileage until the STs came out, and suddenly there were guys putting 30k a year on the bikes. Found a few issues in the design.
Cheers, Phil.
Cheers, Phil.
- bmw851
- model: other
If you've had no luck yet also try
http://www.motoitalia.com.au/
Dave Ward
or Italspares Jim or Ian
02 6946 2626
Peter
Dave Ward
02 6946 2626
Peter
- ducinthebay
Got a box of spare bits from a guy. In it was a front sprocket and a retaining plate. The sprocket looked pretty good, but the retaining plate had about half of the material worn away on the tabs that hold the sprocket on. it was pretty close to failure. Definitely a replaceable item.
I totally agree.paso750 wrote: Tell your local dealer he`s an idiot if he doesn`t know that .......omissis........
Never go to a Duc dealer and say you`re looking for parts for an old Duc. Always ask them if they have or can get a certain partnumber. They just need to type that in their computer to check availability w/o having to go through parts catalogues and lose time for something they won`t make any money with. Unfortunately that`s how it is.
btw the dealers now have a new system that allows them to check the old part# against all revisions and identify if is still available or if there is any other model that fits the same; most of the old part#s have been superceded by the new number system but the dealer has access to the whole story so if they want they can help.
I have been ordering very old parts since "forever" and only when the part is really NLA then I get stuck, usually is bodywork or electrics and few mechanical parts, but most of them are still available.
