Anybody got a hot tip as to who could supply me some offset keys . I have struck out locally ( no bastard could be bothered even returning my e-mails ) and uncle Ian ( Gowanloch ) hasn't replied either . Im pickin that someone either in Aus or the US will know someone .
Hamish
Offset keys .. cam pulley's
Re: Offset keys .. cam pulley's
Hamish
I got mine from Brad Black in Melbourne. I took them out when I got a set of adjustable pulleys, still have them in a box somewhere. From memory one was 5 deg and the other 6 deg. I don't need them any more.
What size are you after?
I need 4 and 8 deg as my lobe centers are at 111 deg and 114 deg . The thinking being that I can fit both and get 106/107 deg lobe centers , or just fit the 4 deg one and have 110/111 deg lobe centers. One thing bugs me is that I get 270 deg duration on the vert cyl and 272 on the horiz cyl. I have done the measurements several times and checked the method heaps ( zero lash , correct TDC , duration at 40 thou valve lift)..... beats me
I would rather have adjustable pulleys but they aint as easy to find as you'd think . Epicycle will modify my own pulleys if I send em over the ditch , not sure I can be bothered with that tho.
Hamish
Hamish
Cheers Ken , They are on there wayDuc906 wrote:Hamish
Andrew2
Hey Hamish,
how about a pictorial on what you're doing.I don't know shit about timing so I might learn something.
Andrew
Andrew
Yeah , Ok ( always fancied myself as a movie star ) , when these keys get here I will sort it out on camera
( Warning , contents may contain low level violence and offensive language )
No probs, good to hear that Brad could help you out.Mc tool wrote:Cheers Ken , They are on there wayDuc906 wrote:Hamish
As for the difference in duration, you have come up with the same duration specs that I measured on my bike. I measured mine at least 10 times when I was playing around with the cams but I still came up with the same durations?
Maybe Mr Black might chime in here and have an explaination for it.
Good luck with you're new career change as a movie star, break a leg.
Very funnyDuc906 wrote: Good luck with you're new career change as a movie star, break a leg.
