PasoRoo wrote:Jon,
It seems your alternator wiring has melted in exactly the same interesting, chocolatey, way as mine.
Yeah, crappy connections and corrosion make for a high heat joint. It's all been fixed up tho.
PasoRoo wrote:Jon,
I like this reg it has the letters and you can see the wires i have had left, since fitting the rr51. one pink. one red. (one blue one, which i joined to the white on rr51.Desmo_Demon wrote:Here's my '87 P750 as stock (without the wiring upgrade performed, yet)...
desmodave wrote:I like this reg it has the letters and you can see the wires i have had left since fitting the rr51 the pink one red one blue one(which i joined to the white on rr51.Desmo_Demon wrote:Here's my '87 P750 as stock (without the wiring upgrade performed, yet)...
whats the part no for this reg? my bike is 89paso. has it beeen reliable? e.g not drained off the batt!!
hope everyone who has a rr51 or doesnt. understands the remaining wires that go nowhere now!desmodave wrote:desmodave wrote:I like this reg it has the letters and you can see the wires i have had left since fitting the rr51 the pink one red one blue one(which i joined to the white on rr51.Desmo_Demon wrote:Here's my '87 P750 as stock (without the wiring upgrade performed, yet)...
on a second qoute this is the answer ive been looking for although your bike is a little earlier than mine the pink the extra red (not the alt red!) blue and i have two green joining which connected to reg like your single one.
cheers j! p.s hope you watch the 4 nations rugby league!!!jayh wrote:Thats strange I'm sure this reply was in another thread before
anyways the reply remains the same :
If your wiring is indeed fried or aged,it should be replaced with a good quality silicone coated wire that can handle the hot engine oil.This type of wire can be purchased from appliance repair shops,its used in things that get hot like toasters etc.
You will need to make or purchase a puller to remove the altenator cover.This bolts into the electronic ignition badge holes on the side of the altenator cover and pushes on the end of the crankshaft,to facilitate its removal.The wiring comes away with the altenator cover,you may want to consider doing your ignition pickup wiring at the same time as it is prone to heat damage too.At the very least check that there are no bits of magnetised metal hanging of the ends of the pickups and that their gap is correct. J.
That`s me. If I didn`t merge some of Dave`s threads there would be now 7 or 8 (if I counted well) on one very same topic.Thats strange I'm sure this reply was in another thread before
PasoRoo wrote:Jon,
It seems your alternator wiring has melted in exactly the same interesting, chocolatey, way as mine. I recently cut the wires back to where they were halfway decent and crimped new connectors on. It went from this: to this: and a photo of the complete setup for Desmodave: Although the setup is slightly different now because I installed a HiCap kit.
Mike
God thats poor!and those are they near the swing arm will earth on the swingarm by the un taped up cconnecters!!Desmo_Demon wrote:I corrected my caption with the picture above in the thread. That was a picture of the underseat electronics BEFORE I did the wiring upgrade. It was after I had done some wiring repairs.desmodave wrote:Closest to mine what is the earth for nearest side left as your sat on it???Desmo_Demon wrote:
The upper ground on the voltage regulator is for the relay. The lower ground on the regulator goes directly to the point on the frame where the negative battery cable connects to the frame. It is the green to black wire with the yellow butt splice connecting them in the second picture below.
Also, my stator wires are green because I replaced them from the engine case all the way to the regulator. The wires were in such bad shape that I had to replace them. The insulation was dry, discolored, and sections of the insulation was either missing or crumbled as I touched them. I also think I went with a little larger gauge wire than stock.
This is what some of the wiring looked like when I first got the bike...
ta g. pink? is this your own colour wiring! so thats g.g.r. y.y.r any more alternator colours!paso750 wrote:there is no B+, there`s only a R+ and a B. Those are connections on the regulator/rectifier. B goes to the battery + via the starter relais and R+ goes to the alternator.
nah! blooming heck! you just have 2 wire alt (of course) so i would if i had this reg wire up as the rr51 but i would have the added extra of my pink blue and 2 g/gb join too! mystery solved!desmodave wrote:ta g. pink? is this your own colour wiring! so thats g.g.r. y.y.r any more alternator colours!paso750 wrote:there is no B+, there`s only a R+ and a B. Those are connections on the regulator/rectifier. B goes to the battery + via the starter relais and R+ goes to the alternator.
