Need some 907 Fairing parts
- du907
Does anyone have a line on 907IE lower fairing for bot sides and the front fairing (piece around headlight)?
I could also use the front sub frame that the headlight bolts to (for 907) and Headlight.
Thanks again
Bryon
Thanks again
Bryon
- Bock900r
Re: Need some 907 Fairing parts
I think the best thing is this http://www.airtech-streamlining.com/duc ... 991-92.htm
its in your Country and the quality looks good.
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
http://cgi.ebay.com/ebaymotors/Ducati-P ... ccessories
that is the stay. Ed at Guzzitech can provide the correct one for you as well as a headlight or anything else you may require
http://stores.ebay.com/guzzitech
that`s not a 907ie front frame.
I can`t help it but not only are some parts from guzzitech expensive but also what he describes as "good shape" is something different in my definition.
Just one example (and looking at the condition it`s probably from the same Paso that front frame came from)
http://cgi.ebay.com/ebaymotors/Ducati-P ... 3f0a67d50a
Yes G you are correct and yes till Ed gets to know you he gets a good price especially during the racing season.
The 907 is slightly different,not a big deal. Least not to me
I have received many parts from Ed for reasonable prices in good shape,not brand new perfect shape but usable with out a lot of work.
I did get parts from him too and was happy with them. Just saying some things he has on ebay can be found cheaper. Ie good BUBs can be found sometimes for $150.
Can`t remember the exact differences in the front frames although I had one from a 907ie once. It should at least have a mount for the coolant reservoir on the right. Don`t know if the 907ie has some electronics on the left side the other models don´t have. If so there will be another mount missing.
The big difference is the mounting ears for the relay panel which the 750 and the 906 do not have
Unless of course you rewire the bike like I did and welded on the tabs for the relays and such
I did want to buy the ST2 cams from Ed at one point. Initially The price was difficult to swallow and I asked him if he was late on a boat payment,it was worse than that,he was starting his racing season. But to be fair he didn't want to part with them anyway as he could use them himself. In the end he asked me to make an offer,I decided to wait for another set and as you know ST2 cams are on intergalactic backorder
your a week late, there was a complete engine with broken mounts on US Desmo for $400.
du907,
I have all three of those parts, but they will need a little work. I'll send pictures if you're interested.
Bob
Bob
- du907
Bob, my hero. Yes I'm interested. The pieces I have after my wreck "need a little work" too. Please send and pictures you might have.
du907@earthlink.net
Thanks again
Bryon
du907@earthlink.net
Thanks again
Bryon
- JoKing
Uh... if i`d read that before...
There was a front frame listed on ebay, ended yesterday, sold for 1€.....
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
I'll get some pictures taken and sent in the next few days, Bryon.
