After a useful chat with Derek and Geoff at Baines Racing I learned that all 600, 750 and 900 Mikuni equiped 2-valve desmos have exactly the same 38mm carbs, only the jets being different. They weren't sure if the manifolds are a direct fit but I have a set from a 900FE on the way so I shall let you know when they arrive.
What I forgot to ask is whether the Mikuni equiped Ducatis use a fuel pump or are gravity fed. Can anyone answer this?
Steve.
Fuel pump and Mikunis
bauhaus
Re: Fuel pump and Mikunis
I have the Mikuni's in mine and it does have a fuel pump, but I got the bike used and don't know if the fuel pump is required.speedtrifle wrote:What I forgot to ask is whether the Mikuni equiped Ducatis use a fuel pump or are gravity fed. Can anyone answer this?
Steve.
My shop manual shows the Webber carbs, which require a fuel pump. It has no information on the Mikuni.
If the fuel inlet on the carb is below the petcock valve you may not need a fuel pump, gravity may do the job.
Bill
I Use in my Paso 88 a pair of mikuni 38mm from a monster 750, with the original fuel pump, and they work very well.
70 hp. can change the world
v2block
its usefull to have the fuel pump, because the lowest tankpoint and petcock is below the float-chamber. i mounted 900ss mikunis with fuelpump and the importend overfill return. works great ,specially if you know the weber shit. with the weber i floated always the cylinders, and all the other problems. thanks to gerhard !!! (paso 750)
