Got Oil?
Got Oil?
Just a quick survey before I open another topic for discussion
What oil do you use in your Paso ?
Re: Got Oil?
Ran Across this old Quack.faq Had some basic info even if a little dated..........
This FAQ was originally maintained by Jon Wright, and then by Duke Robillard for a while.
17. "Which oil is best for my Duck? Can I use car oils?"
More Than You Ever Wanted to Know About Motor Oil.
by Ed Hackett (edh@maxey.unr.edu)
(Editor's Note: before you read all this, you might want to consider the short answer from Julian Bond : "Pretty much any synthetic motorcycle oil can be used such as Silkolene Pro-4 or the motorcycle version of Mobil 1. The factory recommend Agip 4T Super racing which is a 5W/40 grade synthetic." Personally, I think you can use any brand name, so long as you change it every 6 weeks. :->)
Choosing the best motor oil is a topic that comes up frequently in discussions between motoheads, whether they are talking about motorcycles or cars. The following article is intended to help you make a choice based on more than the advertising hype.
Oil companies provide data on their oils most often referred to as "typical inspection data". This is an average of the actual physical and a few common chemical properties of their oils. This information is available to the public through their distributors or by writing or calling the company directly. I have compiled a list of the most popular, premium oils so that a ready comparison can be made. If your favorite oil is not on the list get the data from the distributor and use what I have as a data base. This article is going to look at six of the most important properties of a motor oil readily available to the public: viscosity, viscosity index (VI), flash point, pour point, % sulfated ash, and % zinc. Viscosity is the measure of how thick an oil is. This is the most important property for an engine. An oil with too low a viscosity can shear and loose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to "real" viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at 0 F and is therefore suitable for Winter use.
The following chart shows the relationship of "real" viscosity to their S.A.E. assigned numbers. The relationship of gear oils to engine oils is also shown.
_____________________________________________________________
| SAE Gear Viscosity Number |
| ________________________________________________________ |
| |75W |80W |85W| 90 | 140 | |
| |____|_____|___|______________|________________________| |
| SAE Crank Case Viscosity Number |
| |10| 20 | 30 | 40 | 50 | |
| |__|_____|____|_____|______| |
|_____________________________________________________________|
2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42
viscosity cSt @ 100 degrees C
Multi viscosity oils work like this: Polymers are added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
Multi viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter base your decision on the lowest temperature you will encounter, in the summer, the highest temperature you expect. The polymers can shear and burn forming deposits that can cause ring sticking and other problems. 10W-40 and 5W-30 require a lot of polymers (synthetics excluded) to achieve that range. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best.
Very few manufactures recommend 10W-40 any more, and some threaten to void warranties if it is used. It was not included in this article for that reason. 20W-50 is the same 30 point spread, but because it starts with a heavier base it requires less viscosity index improvers (polymers) to do the job. AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Mobil 1 uses no viscosity improvers in their 5W-30, and I assume the new 10W-30. Follow your manufacturer's recommendations as to which weights are appropriate for your vehicle.
Viscosity Index is an empirical number indicating the rate of change in viscosity of an oil within a given temperature range. Higher numbers indicate a low change, lower numbers indicate a relatively large change. The higher the number the better. This is one major property of an oil that keeps your bearings happy. These numbers can only be compared within a viscosity range. It is not an indication of how well the oil resists thermal breakdown.
Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendency for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption. Flash point is in degrees F.
Pour point is 5 degrees F above the point at which a chilled oil shows no movement at the surface for 5 seconds when inclined. This measurement is especially important for oils used in the winter. A borderline pumping temperature is given by some manufacturers. This is the temperature at which the oil will pump and maintain adequate oil pressure. This was not given by a lot of the manufacturers, but seems to be about 20 degrees F above the pour point. The lower the pour point the better. Pour point is in degrees F.
% sulfated ash is how much solid material is left when the oil burns. A high ash content will tend to form more sludge and deposits in the engine. Low ash content also seems to promote long valve life. Look for oils with a low ash content.
% zinc is the amount of zinc used as an extreme pressure, anti-wear additive. The zinc is only used when there is actual metal to metal contact in the engine. Hopefully the oil will do its job and this will rarely occur, but if it does, the zinc compounds react with the metal to prevent scuffing and wear. A level of .11% is enough to protect an automobile engine for the extended oil drain interval, under normal use. Those of you with high revving, air cooled motorcycles or turbo charged cars or bikes might want to look at the oils with the higher zinc content. More doesn't give you better protection, it gives you longer protection if the rate of metal to metal contact is abnormally high. High zinc content can lead to deposit formation and plug fouling.
The Data:
Listed alphabetically --- indicates the data was not available
Brand VI Flash Pour %ash %zinc
20W-50
AMSOIL 136 482 -38 <.5 ---
Castrol GTX 122 440 -15 .85 .12
Exxon High Performance 119 419 -13 .70 .11
Havoline Formula 3 125 465 -30 1.0 ---
Kendall GT-1 129 390 -25 1.0 .16
Pennzoil GT Perf. 120 460 -10 .9 ---
Quaker State Dlx. 155 430 -25 .9 ---
Red Line 150 503 -49 --- ---
Shell Truck Guard 130 450 -15 1.0 .15
Spectro Golden 4 174 440 -35 --- .15
Spectro Golden M.G. 174 440 -35 --- .13
Unocal 121 432 -11 .74 .12
Valvoline All Climate 125 430 -10 1.0 .11
Valvoline Turbo 140 440 -10 .99 .13
Valvoline Race 140 425 -10 1.2 .20
Valvoline Synthetic 146 465 -40 <1.5 .12
20W-40
Castrol Multi-Grade 110 440 -15 .85 .12
Quaker State 121 415 -15 .9 ---
15W-50
Chevron 204 415 -18 .96 .11
Mobil 1 170 470 -55 --- ---
Mystic JT8 144 420 -20 1.7 .15
Red Line 152 503 -49 --- ---
5W-50
Castrol Syntec 180 437 -45 1.2 .10
Quaker State Synquest 173 457 -76 --- ---
Pennzoil Performax 176 --- -69 --- ---
5W-40
Havoline 170 450 -40 1.4 ---
15W-40
AMSOIL 135 460 -38 <.5 ---
Castrol 134 415 -15 1.3 .14
Chevron Delo 400 136 421 -27 1.0 ---
Exxon XD3 --- 417 -11 .9 .14
Exxon XD3 Extra 135 399 -11 .95 .13
Kendall GT-1 135 410 -25 1.0 .16
Mystic JT8 142 440 -20 1.7 .15
Red Line 149 495 -40 --- ---
Shell Rotella w/XLA 146 410 -25 1.0 .13
Valvoline All Fleet 140 --- -10 1.0 .15
Valvoline Turbo 140 420 -10 .99 .13
10W-30
AMSOIL 142 480 -70 <.5 ---
Castrol GTX 140 415 -33 .85 .12
Chevron Supreme 150 401 -26 .96 .11
Exxon Superflo Hi Perf 135 392 -22 .70 .11
Exxon Superflo Supreme 133 400 -31 .85 .13
Havoline Formula 3 139 430 -30 1.0 ---
Kendall GT-1 139 390 -25 1.0 .16
Mobil 1 160 450 -65 --- ---
Pennzoil PLZ Turbo 140 410 -27 1.0 ---
Quaker State 156 410 -30 .9 ---
Red Line 139 475 -40 --- ---
Shell Fire and Ice 155 410 -35 .9 .12
Shell Super 2000 155 410 -35 1.0 .13
Shell Truck Guard 155 405 -35 1.0 .15
Spectro Golden M.G. 175 405 -40 --- ---
Unocal Super 153 428 -33 .92 .12
Valvoline All Climate 130 410 -26 1.0 .11
Valvoline Turbo 135 410 -26 .99 .13
Valvoline Race 130 410 -26 1.2 .20
Valvoline Synthetic 140 450 -40 <1.5 .12
5W-30
AMSOIL 168 480 -76 <.5 ---
Castrol GTX 156 400 -35 .80 .12
Chevron Supreme 202? 354 -46 .96 .11
Chevron Supreme Synth. 165 446 -72 1.1 .12
Exxon Superflow HP 148 392 -22 .70 .11
Havoline Formula 3 158 420 -40 1.0 ---
Mobil 1 165 445 -65 --- ---
Mystic JT8 161 390 -25 .95 .1
Quaker State 165 405 -35 .9 ---
Red Line 151 455 -49 --- ---
Shell Fire and Ice 167 405 -35 .9 .12
Unocal 151 414 -33 .81 .12
Valvoline All Climate 135 405 -40 1.0 .11
Valvoline Turbo 158 405 -40 .99 .13
Valvoline Synthetic 160 435 -40 <1.5 .12
All of the oils above meet current SG/CD ratings and all vehicle manufacturer's warranty requirements in the proper viscosity. All are "good enough", but those with the better numbers are icing on the cake. The synthetics offer the only truly significant differences, due to their superior high temperature oxidation resistance, high film strength, very low tendency to form deposits, stable viscosity base, and low temperature flow characteristics. Synthetics are superior lubricants compared to traditional petroleum oils. You will have to decide if their high cost is justified in your application.
The extended oil drain intervals given by the vehicle manufacturers (typically 7500 miles) and synthetic oil companies (up to 25,000 miles) are for what is called normal service. Normal service is defined as the engine at normal operating temperature, at highway speeds, and in a dust free environment. Stop and go, city driving, trips of less than 10 miles, or extreme heat or cold puts the oil change interval into the severe service category, which is 3000 miles for most vehicles. Synthetics can be run two to three times the mileage of petroleum oils with no problems. They do not react to combustion and combustion by-products to the extent that the dead dinosaur juice does. The longer drain intervals possible help take the bite out of the higher cost of the synthetics. If your car or bike is still under warranty you will have to stick to the recommended drain intervals. These are set for petroleum oils and the manufacturers make no official allowance for the use of synthetics.
Oil additives should not be used. The oil companies have gone to great lengths to develop an additive package that meets the vehicle's requirements. Some of these additives are synergistic, that is the effect of two additives together is greater than the effect of each acting separately. If you add anything to the oil you may upset this balance and prevent the oil from performing to specification.
The numbers above are not, by any means, all there is to determining what makes a top quality oil. The exact base stock used, the type, quality, and quantity of additives used are very important. The given data combined with the manufacturer's claims, your personal experience, and the reputation of the oil among others who use it should help you make an informed choice.
- jcslocum
Re: Got Oil?
Mobill1 10-40 moto oil usually. Good for a few more HP due to less pumping loss. 20-50 when I don't have 10-40.
- englishstiv
Re: Got Oil?
Obviously a keen representative and adviser to the oil industry then.Stop and go, city driving, trips of less than 10 miles, or extreme heat or cold puts the oil change interval into the severe service category, which is 3000 miles for most vehicles.
I have got to admit that under normal yearly driving conditions I would never buy any oil unless I can get at least 15,000 UK miles on a service out of it. What I do though is add into every engine a good protective agent when I first take ownership irrespective of where it might of come from and replace that at the oil change intervals.
With an old Ford Transit that I had an oil change was a two yearly 60,000 mile event with not an ounce of engine trouble or apparent wear when I did a de-coke check after running straight vegetable oil and acetone for 4 years.
I appreciate some of you live in hostile environments so it might be a little more important but over here in blighty we never know whether it will be sunny the morning and lashing it down in the evening but it's never so too hot or so too cold to ride.
It's the same with petrol over here all sorts of wonderful additives that now make you go an extra 5 miles between tank refills the same effect was obtained with a 20 ml addition of Acetone in the tank at almost £15.00 less in cost it also helps with damp starting conditions.
I also have a friend who sends oil to Ghana that has come from his Garage and is used to keep a fleet of Taxi's running over there for his nephew all they do is filter it and check it's viscosity he likens it to making a good blended scotch whiskey
DUCATI 907ie 1992
- Finnpaso
- year: 0
Re: Got Oil?
Fully synthetic Shell Advance Ultra 4 15W-50. No anykind oil problems.....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
Re: Got Oil?
In the past I have used AMSoil in my two wheeled vehicles and Durablend in the 4 wheeled(4X4 FRONTIER AND XTERRA).
Both of these oils are getting harder to find all the time and with my work schedule it seems I always forget to order it ahead of time.
The 907ie needed an oil change now,as it was a quart low and I never changed it out to begin with( yeah I am still on five year old belts as well and even older tires ) no time to get the AMSoil I usually use.
So...I went with the Mobil one 0w40. I've been seeing some good things with the 0W40 and 0W30 oils. Amazing things actually Engines with over a thousand hard hours on the dyno that even the cams look brand new and that is very unusual indeed
AMSoil because they manage to get the proper viscosity with far less polymers than other oils.( That I have tried anyway, 35 years of tearing down engines and trannies on just about every vehicle you can name )
Less polymers is good,less zinc is also good. I realize a lot of folks insist on racing blends for their street bikes. The issue I have with racing oils in bikes that are not used to race is the zinc content. Zinc means sludge,polymers also mean sludge. So unless you are pulling your engine apart on a regular routine racing oils are not a good thing period. So anyway I am taking the plunge, a big leap of faith with anything from Mobil ( I do appreciate your response on the subject Jon, not to diss the rest of you that responded )
Again thanks to all of your input
So let the discussion\rebutals\expression of opinion begin
Re: Got Oil?
I've always used the ducati recommended 20-50w but with the advancements in technology over the years I would like to know if there is something better I could be using.
- jcslocum
Re: Got Oil?
Higgy,
Stick to the moto oils. They will stand up much better to the beating the trans gives it compared to auto oil.
- Maico88
Re: Got Oil?
Don't have a Paso, but I do have a 750 Sport. I follow all of the topics with great interest. I have been using Lucas 20-50w synthetic oil. It was not one of the oils listed in this thread. Anyone know about lucas oil?
Re: Got Oil?
http://www.amsoil.com/lit/g2156.pdf
An updated report on Motorcycle oils,sponsored by AMSoil but still an accurate account
No Lucas oil info,but from what I know about it Lucas oil is a decent quality oil that has been around for a while I believe it had its roots in the dirt track racing which means they have a lot of experience with high heat and high loading
PS sorry Jon,the last 30 years there are a lot more auto's running around with motor oil in their trannies than motorcycles ever built . It really comes down to resistance to shearing forces that makes a quality oil
- jcslocum
Re: Got Oil?
I've heard of Lucas oil and went to the Lucas mile while in Indy this year. I think they are located in Indy (Lucas Stadium where the Colts play) and have stuff for the trucking industry too.
I don't think they make Moto oils but I don't know for sure.
- jcslocum
Re: Got Oil?
Please give a couple of examples of autos that run motor oil in the manual trans. I'm not aware of any. :-)higgy wrote:http://www.amsoil.com/lit/g2156.pdf PS sorry Jon,the last 30 years there are a lot more auto's running around with motor oil in their trannies than motorcycles ever built . It really comes down to resistance to shearing forces that makes a quality oil
Re: Got Oil?
Can you spell Honda? Chevrolet? Ford?
There's a few for ya
- jcslocum
Re: Got Oil?
Who'da thunk it.....
- Desmo_Demon
Re: Got Oil?
This is true. My 1995 Civic EX with manual tranny has been running 10w-40 for over 262k miles without any issues. I was actually shocked to read in the owner's manual to use engine oil in the tranny. I've been using the cheapest stuff I can find, too. I mean, it is a Honda, right?higgy wrote:Can you spell Honda? Chevrolet? Ford?
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
